Activity Forums Apple Final Cut Pro Legacy Outpoint over run
  • Outpoint over run
    Posted by Lansford B on November 3, 2005 at 5:06 pm
    I am having a problem with FCP 5. Several problems. When I am trying to capture a clip, if the clip makes it thru without any reported timecode breaks the capture feature does not stop at the set out point. it over runs the out point and I have to abort the capture to stop the running. The next time i try to capture that same clip FCP tells me there were timecode breaks and stops the capture. Media100 captures this clip just fine. How do i stop FCP from running away?
    Lansford B replied 20 years, 10 months ago 2 Members · 2 Replies
  • Kevin Monahan
    November 3, 2005 at 7:41 pm
    What kind of deck are you using? Perhaps it’s not certified for use with FCP.
    Kevin Monahan
    Take My FCP Master’s Seminar!
    fcpworld.com
  • Lansford B
    November 3, 2005 at 7:59 pm
    The deck I am using is a Sony DSR-80 DVCam. The signal routes thru a matrix switcher to an AJA IO LA Box and to the G5 by firewire.
