Activity Forums Adobe Illustrator outer glow disappeared
  • outer glow disappeared
    Posted by Laura Shapiro on May 24, 2010 at 10:14 am
    Hi, All.
    I used an outer glow effect in my illustrator project. I saved it as a pdf. When I open the pdf in acrobat, the outer glow appears normal. When I open it in preview, the outer glow is so faint, it’s hardly visible. Is there something I can do to fix this discrepancy? Can I save the file in a different way so that the glow will be consistent?
    Laura
    Vincent Rosati replied 16 years, 3 months ago 2 Members · 1 Reply
  • Vincent Rosati
    May 30, 2010 at 7:16 pm
    I’m sure that if you saved the file as a raster image you would see the drop shadow.
    That would work, but I’m kinda’ being a smarty pants.
    If your subject is white and you just can’t see it in the preview, maybe you could add a layer in the file with a dark background.
    I don’t think that Adobe ever liked the idea that Apple added PDF support to Preview, so perhaps there are just going to be some limitations.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
