Activity Forums Apple Final Cut Pro Legacy out putting standard definition In FCp from the sony EX3
  • out putting standard definition In FCp from the sony EX3
    Posted by Daniel Robertson on January 12, 2009 at 10:21 am
    hello,
    I have edited a short film shot on an EX3, was enquiring the best work flow to go from FCP (studio 2) to DVD. the DVD has to be of a high quality cause it will be played on a large screen. I’ve tried a few ways on compressor but it comes out very murky.
    does anyone know a way to get a 6 minute film shot in HD on to a -R dvd?
    your help would be greatly appreciated!
    cheers
    Chris Poisson replied 17 years, 8 months ago 3 Members · 2 Replies
  • Rafael Amador
    January 12, 2009 at 10:32 am
    Hi Daniel,
    Compressor is able to make a very good job as long as you set the “Frame Control ON”.
    Normally I downsize to SD in FC. Then I send to Compressor. If you send your clip already as SD to Compressor, only the transcoding to MPG-2 have to be done.
    To downscale in FC I make an SD sequence and I drop the HD sequence or HD movie on it.
    Set “Render all YUV material in High Precission YUV” and “Rendering Motion Effects: Best”.
    Then you only need to send to Compressor.
    having a duration of only 6 minutes you can rise the data rate of your MPG-2 to get a better picture.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Chris Poisson
    January 12, 2009 at 4:38 pm
    I do what Raphael does minus one step: I leave my HD sequence native with his method of the YUV settings, render and export a self-contained movie, then let Compressor do the downconvert with the frame controls set the way he does.
    Have a wonderful day.
