Activity › Forums › Media 100 › Out of sync audio.
  • Out of sync audio.
    Posted by Gregg Michaels on June 1, 2007 at 6:34 pm
    New Media100 HDe system PPC 11.5.1, Dual G5 2.7ghz
    Digitizing 20 talking head clips shot on digi beta via the sdi port. Audio and video are acquired over sdi using the Media100HD codec, and everything is 10 bit uncompressed. Monitor is hooked up to component analog, and the “audio sync to” setting is set to analog. Most clips were not in sync with the video. The difference ranged from 4 frames to 12 frames. In all cases the audio was late. I found a previous post very similar to this, but there appeared to be no resolution. Any help is appreciated.
    Gregg Michaels replied 19 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
