Activity › Forums › Apple Final Cut Pro Legacy › Out of sync audio from Compressor
  • Out of sync audio from Compressor
    Posted by Daryl Lannert on September 23, 2009 at 8:52 pm
    Hello,
    We are trying to standards convert a 50min NTSC Apple ProRes 1080i file to PAL Apple ProRes 1080i through compressor. Every time we send it through, we receive a file with with audio gradually slipping out of sync. First 10-15 minutes seem fine but by minute 30, we are out of sync. Any help would be greatly appreciated. Thank you.
    John Fishback replied 17 years ago 3 Members · 3 Replies
  • Jeremy Garchow
    September 23, 2009 at 9:04 pm
    Hoe are you doing the standards conversion?
    What I mean is, what settings are you using?
  • Daryl Lannert
    September 24, 2009 at 2:16 pm
    Here are our settings:
    Under the Encoder tab –
    Video – Apple ProRes, 25FPS
    Audio – Linear PCM, Stereo, 48 KHZ Render settings-Normal, PCM Settings 24bit.
    Streaming – none
    Under The Frame Controls Tab –
    Frame Controls-On
    Resize Filter – Better
    Output Fields – Top first
    Deinterlace – Fast
    Adaptive details – Check
    Rate Conversion – Fast
    Set Duration – We have used both % of source and “So Source Frames Play at 25FPS”
    Under the Filters Tab – None
    Under the Geometry tab –
    Frame Size – Grayed out 1920 x1080 – 100% of source
    That is all of the settings we are using. Hopefully you can find something we are doing wrong. Thanks for your help.
  • John Fishback
    September 27, 2009 at 7:25 pm
    I’ve not used Compressor for standards conversion. I use Nattress for that. I suggest at the very least you set Compressor’s Rate Conversion quality setting to Best. When changing a clip’s scaling or timebase with Compressor, I always go with Best quality settings.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
