Activity › Forums › Panasonic Cameras › Out of Order Clips – searched 1st found nothing
Posted by Jake Hawkes on May 13, 2008 at 11:26 pmIn premier Pro I am just draggin my video clips right into my bin. If I then drag them all onto the timeline they are all out of order…lots of time remembering how theday went…Arghh!
Any advice on this would be greatly appreciated.
Gravnetic Production
You’ve had our patatoes!http://www.Gravnetic.com
1 208 867 8172
Moocycles@hotmail.comJeremy Garchow replied 18 years, 3 months ago 3 Members · 9 Replies -
Jeremy Garchow
May 14, 2008 at 2:57 amThe clips don’t get recorded in chronological AND numerical order. Sort your bin by timecode and your clips will then be in chronological order.
Jake Hawkes
May 14, 2008 at 8:44 amThanks…soooo much!!!
1 208 867 8172
Moocycles@hotmail.com -
Bo Skelmose
May 14, 2008 at 12:34 pmThat is why I always use the clock as timecode – gives you a perfect view of the days recordings.
Jake Hawkes
May 14, 2008 at 4:53 pmSheesh,
Adobe doesn’t even use the term timcode. I haven’t seen the bin column that represents the timecode, more searching.
Thanks for the heads up, and I like the clock idea you mentioned.
1 208 867 8172
Jeremy Garchow
May 14, 2008 at 6:01 pm[Jake Hawkes] “Adobe doesn’t even use the term timcode.”
Really? There has to be something. Media Start, Media End, In Point, Out point, something. A bunch of numbers that follow this pattern 00:00:00:00
If you don’t see it now there has to be a way to reveal it. I don’t know enough about Premiere to point you in the right direction. In Final CUt you simply right click by the column headings to reveal more column options. Being an Adobe product, you might have to reveal the pane view options by the little triangle on the pane?
Jeremy
Jake Hawkes
May 14, 2008 at 6:11 pmFound it…
It is a tiny little arrow in the upper right corner of the Project Bin Panel. Then clicking Edit Columns gives you the various column options as check boxes.
I sorted by Media End and it looks to be back in order.
This is such a huge timesaver, and really I hand blown off timecode bacause it is a tapless environment.
Thanks for all the help, YOU ROCK LIKE AC/DC in ’78.
The other thing that is getting me are the projects settings, but I will cruise over to the PPro Forum fo that!
1 208 867 8172
Jeremy Garchow
May 14, 2008 at 6:35 pm[Jake Hawkes] “YOU ROCK LIKE AC/DC in ’78. “
How ’bout the Scorpions Circa 1989….in Moscow
Jake Hawkes
May 14, 2008 at 7:08 pmAs they say over her ein Jackson Hole…SIIIIACK!
So just to round trip this issue for anyone that reads this I didn’t shoot with my HVX200 in the correct Timecode setting, so it looks like I will be doing a manual assembly which is fine because it is only one day.
Besides I have the Scorpions to keep it real!
1 208 867 8172
Jeremy Garchow
May 14, 2008 at 7:16 pm[Jake Hawkes] “So just to round trip this issue for anyone that reads this I didn’t shoot with my HVX200 in the correct Timecode settin”
What do you mean by this?
