Activity › Forums › Apple Final Cut Pro Legacy › Out of Memory Issue
  • Out of Memory Issue
    Posted by Mark Fanjoy on October 23, 2011 at 7:13 am
    Is there another reason I could be experiencing “Out of Memory” notices when I attempt a render, other than over sized still images, which I know can cause this?
    I have plenty of RAM memory, usually about 8-9gigs showing. If I shut down FC and re boot, the problem usually goes away, but eventually creeps back in.
    Sort of a side bar, during these conditions I will also get a big red “missing Codec” indication as well. Usually after a couple of render attempts, that one goes away. But re appears randomly.
    Is there a Cache limit or something I don’t know about?
    Thanks.
    Wherever I am…I’m lost!
    Jerry Wise replied 14 years, 11 months ago 3 Members · 2 Replies
  • Stephen Smith
    October 24, 2011 at 4:33 pm
    When I have gotten an Out of Memory notice I restarted the computer and everything returned to normal.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
  • Jerry Wise
    October 24, 2011 at 8:14 pm
    i also get “out of memory” if i have my sequence set to “Video Processing” “Render 10 bit material in high precision YUV”
    i usually set it to RGB or 8 bit YUV.
