Activity Forums Adobe After Effects “out of memory” “image buffer” errors when rendering
  • “out of memory” “image buffer” errors when rendering
    Posted by Chris Cummings on March 20, 2008 at 5:15 pm
    Hi All,
    I have a dual 2.5 PowerMac with 4.5GB of RAM, and it seems every time I try to render out of AE (CS3) I get errors – either “out of memory” or “could not create image buffer”. I’ve never had any problems rendering out of C4D or Motion. From research online, it seems this happens to others on occasion, but I was just e-mailing with Eran Stern who found this very strange as he’s working on a less powerful G5 with 2GB of ram and hasn’t ever had any problems.
    I researched this online and this was the best article I found so far:
    https://generalspecialist.com/2006/11/avoiding-after-effects-error-could-not.asp
    Even with these settings applied, I couldn’t get a 5 second HD animation (Eran’s Digit Man tutorial) out until I accessed the “secret menu” and disabled the layer cache, limiting it to 100 frames. I rendered this out as a TIFF sequence.
    However, I have a bunch of greenscreen compositing with a narrator and long takes that I need to start very soon and I’m concerned about the issue above.
    Am I missing something?? Thanks for any help or advice!
    ~Chris
    Philip Richardson replied 16 years, 5 months ago 4 Members · 14 Replies
  • 14 Replies
  • Darby Edelen
    March 21, 2008 at 5:23 pm
    [chris Cummings] “Am I missing something?? Thanks for any help or advice! “
    Doesn’t sound like it, but it would help us understand the issue better if you gave more specifics. What are your Memory & Cache settings exactly? Are you using multiprocessing? What are the dimensions that the buffer error returns?
    These issues can be troubleshot, it just requires that you understand the way that the AE renderer works and walk through the potential problem areas (large layers, large comps, RAM/processor intensive effects, motion blur, depth of field).
    You can read up on AE’s renderer a bit and how to get the most bang for your buck at:
    https://livedocs.adobe.com/en_US/AfterEffects/8.0/WS4E58A2A3-FC7A-49a4-985A-62658804E014.html
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Chris Cummings
    March 21, 2008 at 6:28 pm
    Many thanks for the link and info Darby. This project was HD and probably pretty processor intensive despite being only 5 seconds. Looking forward to reading up on it more in the help link you sent (I’ve always found the manuals a little wanting in details in other apps, but this looks very good).
    My current settings for Memory & Cache are:
    Max memory usage: 160% = 3.0 GB
    Max RAM cache size: 60% = 1.8 GB
    Enable Disk Cache unchecked
    Max Disc Cache size: 12000 MB
    Eran suggested trashing prefs, which I did, but haven’t had a chance to test yet.
    Thanks again,
    ~Chris
  • Nicholas Toth
    March 21, 2008 at 6:44 pm
    Go to your prefs, hold shift and go to Secret in the dropdown.
    Set it to purge ever 1 frame.
    That always worked for me.
  • Chris Cummings
    March 21, 2008 at 7:14 pm
    Hi Nicholas,
    That was exactly the only way I could get this out, but I set it to purge every 100 frames. Just in comparing to others, it seems like I’m encountering this more with a decent computer/set-up. Would still love to get an octo-core Mac though 😉
    Cheers,
    ~C
  • Nicholas Toth
    March 21, 2008 at 7:46 pm
    Don’t get your hopes up;
    We have 2 octos fitted with 32 gigs of ram and they both sported that screen before. We set it to purge after every frame, which hypothetically could add maybe 5-10% of a render time, but who cares if its going to work 100% of the time and not crash. Its such a stupid error!
  • Chris Cummings
    March 21, 2008 at 7:56 pm
    Lol – wow! Those are monsters; guess I don’t feel so bad now 😉
    I’m sure I’ll learn more about the rendering architecture, etc., but it is surprising compared to these other apps where I don’t experience this. That this seems a common enough problem that there has to be a “secret menu” – why not just make it a regular option??
    Cheers, and thanks for the info.
    ~C
  • Nicholas Toth
    March 21, 2008 at 8:19 pm
    buy nucleo pro too, I find I hit the problem less when running that vs. the internal renderer….
  • Chris Cummings
    March 21, 2008 at 9:00 pm
    Good note, thanks Nicholas – I haven’t used AE much in the past, and as such, have a passing knowledge of nucleo pro…I thought it just sped renders up, but if this continues to be a problem, I’ll definitely look into it, esp. with the greenscreen work I have coming up.
    Cheers,
    ~C
  • Darby Edelen
    March 21, 2008 at 10:51 pm
    [chris Cummings] “but it is surprising compared to these other apps where I don’t experience this”
    3D applications generally use a scan line renderer, which doesn’t require much caching. The AE renderer caches each entire layer as it renders so that it can potentially use the cached layer in future frames and avoid re-rendering it entirely. This can get very heavy on RAM as the complexity/size/bit depth of a layer/comp increases.
    The basic rule of AE’s renderer is that if AE can render your largest/most complicated layer without any trouble, the entire composition should render without any problems (this can change with 3D shadows, since those require more than 1 layer to actually be rendered).
    AE renders and caches each layer in a composition separately (not concurrently) and then composites them together, basically this means that you can have 1,000 layers that are each 30×30 pixels and it will never cause problems during render because each layer is cached and rendered separately, but if you have one 30,000 x 30,000 layer your render will fail every time because the memory required to cache this layer is enormous (8 bits per channel * 4 channels * 900000000 pixels ≈ 3.35 GB). If you apply effects to the layer then the RAM required to cache it increases yet again.
    As far as I know, multiprocessing does not help with this, as each processor is delegated a frame of the composition to work on, and a single processor still only has access to 3GB of RAM.
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Darby Edelen
    March 21, 2008 at 10:53 pm
    [Nicholas Toth] “buy nucleo pro too, I find I hit the problem less when running that vs. the internal renderer…. “
    Does Nucleo Pro actually use a different render engine? It seems like it would be hard to guarantee that renders would end up the same as they would out of AE if that is the case. Although Nucleo may have better memory management, until I hear otherwise I think it’s entirely hypothetical =O
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
