Activity › Forums › Adobe After Effects › “out of memory” “image buffer” errors when rendering
Philip Richardson replied 16 years, 6 months ago 4 Members · 14 Replies
Chris Cummings
March 21, 2008 at 11:17 pmThanks for taking time to relay this info Darby, this makes sense.
On this project, there’s a text layer FULL of 14 pt numbers with a scaling random 3D per char. generator, which takes some crunching. Is there a way to essentially “bake” this (like lighting in 3D) so it’s not so processor intensive while working on the project? It sounds doubtful this would help with the render though…
Cheers,
~Chris -
Darby Edelen
March 23, 2008 at 10:25 pm[chris Cummings] “On this project, there’s a text layer FULL of 14 pt numbers with a scaling random 3D per char. generator, which takes some crunching. Is there a way to essentially “bake” this (like lighting in 3D) so it’s not so processor intensive while working on the project? It sounds doubtful this would help with the render though…”
It is my understanding that vector graphics such as text require quite a bit of processing, but I’m not sure how much RAM they actually require.
One suggestion would be to pre-compose a smaller text layer with your random text and bring that pre-comp into your final composition multiple times. It’s unlikely that anyone would notice that the text is repeated if you balance the number of instances of the nested composition with the amount of text in the composition. You could also use time remapping to slightly offset the animations in each instance of the composition.
To maintain the quality and 3D characteristics of your text in your main comp you’ll need to enable collapse transformations on the nested compositions, and then you may not actually be saving any render time/resources… I’m not entirely clear on how AE works with multiple instances of a nested comp with collapse transformations enabled.
So it’s kind of a crap shoot, but perhaps it will help.
Darby Edelen
Designer
Left Coast Digital
Santa Cruz, CA -
Chris Cummings
March 24, 2008 at 4:43 pmGood thoughts – thanks again for your help and advice Darby 🙂
Best wishes,
~Chris -
Philip Richardson
March 27, 2010 at 1:43 pmSome time has passed… but may i just say thank you!
A very blessed post that saved my hair. Why do they make it secret?
P
Phil, Pogo Films Ltd ….UK
Quantel IQ 2K. FCP HD, SD
5 suites, 2 workstations, cables, chairs and headaches.
