Activity › Forums › Apple Final Cut Pro Legacy › Out Of Memory Error Message FCP 7 on Mac Pro with 14 GB RAM
Posted by James Fortier on March 16, 2010 at 11:24 pmThis problem just started after I installed additional RAM, I now have a set of 1 GB, and 6 pairs of 2 GB, total of 14 GB. The only way around the error message is to break clips into smaller clips and render them separately, I also noticed that the render time itself is ridiculously long. I’m running FCP 7 on a Mac Pro 2x 2.66GHz Dual-Core Intel Xeon, with all latest updates installed. System Profiler indicates no errors with any of the RAM DIMMs. Any suggestions would be appreciated.
Mike Kahn replied 14 years, 2 months ago 7 Members · 9 Replies -
David Roth weiss
March 16, 2010 at 11:29 pmBy all means, try taking out the 1Gb sticks and see what happens.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
EPK Colorist – UP IN THE AIR – nominated for six academy awards
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Scott Sheriff
March 16, 2010 at 11:37 pmI have to agree with David. It will probably run better with the 1 gig sticks removed. But I’m guessing there is something else going on. Did you recently upgrade your FCP, or OS? Download an update?
Scott Sheriff
Director
SST Digital Media
https://www.sstdigitalmedia.com -
Michael Sheehan
March 16, 2010 at 11:46 pmHi James,
This might already be something you have considered, but until I got religion about it, the facility I worked for had the most incredibly unreal, hair-tearing bizarre FCP issues. Basically both risers have to have all the same DIMMs laid out the same way on each. 6 on each riser. I concur that adding the 1g DIMMS into the mix is not a good idea. Once I went in a reconfigure every machine to have evenly matched sets of DIMMS of the same type (3 2gs on each, 4 1 gs on each, etc) our problems disappeared.Don’t know if this will help. Hope so.
Cheers
Michael -
James Fortier
March 17, 2010 at 1:32 amturns out the two 1 GB sticks are labeled as 2 GB but showing up as 1 GB each in the system profiler, so clearly they are defective, I removed them, and so far no more error message, but rendering time still seems slow, I’ll order one more set of 2 GB sticks and max this out at 16 GB evenly spread across both risers, thanks for the feedback.
Bryan Banks
March 17, 2010 at 5:26 amI was getting this message yesterday when prepping my friend’s sequence for color… it was a .jpg that was way too big (6k x 4k). scaled that down in PS and everything rendered fine after that.
-Bryan
Mike Kahn
March 17, 2010 at 5:02 pmFCP can only use 2g of RAM no matter how much is in your machine. It is recommended that you have at least 4g to use uncompressed HD so that the machine has 2g and FCP has the full 2g.
This is because FCP is still a 32bit program and 32bit programs can not use more then 2g of RAM ever. Once FCP goes 64bit then all that RAM can get utilized.
James Fortier
March 17, 2010 at 5:32 pmInteresting, I did not know that, thanks for the tip, I’ll put off buying the additional set of 2GB Memory Sticks then.
Mike Kahn
July 11, 2012 at 5:28 pmThis is for the application, not project based. And I was a bit off, 32bit applications can use about 3.5gig of ram, not 2 gig.
