Activity Forums Apple Final Cut Pro Legacy Out of Memory error Importing video files into FC 7
  • Out of Memory error Importing video files into FC 7
    Posted by Juan Lopez on April 23, 2013 at 8:04 pm
    Hello!
    I am about to start editing a tv series on FC 7. I have a huge amount of video files (40tb) distributed in 5 hard drives. All files are in Apple Pro Res format. When I try to import files into the browser I get an “Out of Memory” general error message after importing all the files from the first hard drive what prevent me to import anything else.
    I don’t know if it is problem of Ram or I should introduce other settings for working with so huge amount of video files. I’m working in a Mac Book Pro, 16gb 1600 MHz 2.7ghz Intel Core i7, on Mac OS X 10.8.3
    I really appreciate if someone could help me with this issue.
    Juan Lopez replied 13 years, 4 months ago 2 Members · 2 Replies
  • Neil Patience
    April 23, 2013 at 10:34 pm
    This is quite a common error that pops up pretty regularly. Often it is associated with having stills in a sequence that are larger than 4K or the application or stills cache memory is set too low. Clearly this is not the case here.
    I would suggest that you trash your preferences and see if that helps as a first port of call. You may find that solves the issue.
    It is not usually a RAM issue. Your MBP is way over the spec needed for FCP, it should breeze though.
    Use Digital Rebellions tool https://www.digitalrebellion.com/prefman/
    If not come back and will think again or others will chip in I am sure.
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 FCP7
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 FCP7
  • Juan Lopez
    April 24, 2013 at 5:57 pm
    Thanks Neil,
    I will try with preferences and I’ll let you know if it works
    Cheers
    Juan
