Activity Forums Apple Final Cut Pro Legacy Out of Memory conundrum
  • Out of Memory conundrum
    Posted by Chris Mcelroy on February 14, 2013 at 4:00 am
    I have a small project using video shot by someone in Europe at 25 fps. I have several still images, but the whole video is only 2.5 minutes and not very complex. I’ve loaded this same project on 2 different systems and whenever I try to render, I get the dreaded Out of Memory. My photos are all jpegs and the project fils is only 650kb. any ideas?
    thanks
    Chris Mcelroy replied 13 years, 7 months ago 4 Members · 5 Replies
  • Andrew Kimery
    February 14, 2013 at 4:09 am
    What are the dimensions and file sizes of the JPEGs?
  • Juan Salvo
    February 14, 2013 at 4:21 am
    Use photoshop to convert all the images to png in RGB space, with the smallest possible resolution that allows them to look good. As in, if you have a 1080 sequence, and a 3600×1800 pixel image that you use full frame with no scale. Make that image 2000x? and save as a PNG. Then replace those in your sequence. Adjust your scaling and moves to fit, and I think you’ll find your render are successful.
    Colorist | Online Editor | Post Super | VFX Artist | BD Author
    https://JuanSalvo.com
  • Chris Mcelroy
    February 14, 2013 at 4:47 am
    Thanks, I’ll try this. One of my images was 13MB. I scaled it smaller but still have the problem. I’ll try converting all to png.
    thanks
  • Spencer Averick
    February 14, 2013 at 5:38 am
    What dimensions did you scale it to? Fcp struggles to handle any images that are large in dimension like 2500×2000 for instance. Resize an image in PS so that there are no number values above 1900 or so and it’ll render fine. You can keep it jpg.
  • Chris Mcelroy
    February 14, 2013 at 11:42 pm
    Thanks very much to all for the advice. I scaled the images to under 2000 and everything cleared up and worked. Lesson learned.
