Activity › Forums › Apple Final Cut Pro Legacy › OT…Panasonic AJ-1200a and Sony M25U
Posted by Rich Rubasch on September 6, 2006 at 7:53 pmUltimately I want to upconvert an HDV tape from the Sony M25U deck via firewire to the AJ-1200A deck with the firewire card and I wonder if the Sony properly upconverts so the Panasonic will record a DVCPro HD signal via its firewire input (optional card) and if the timecode will come across matching the source HDV tape.
Also, if you have the firewire card installed in the AJ-1200A is there a second slot for the HD/SD SDI optional card as well, or is it an either/or.
Thanks….I know it’s off topic but I know at least one of you has these answers!
Rich Rubasch
Tilt MediaSean Oneil replied 20 years ago 8 Members · 19 Replies -
Shane Ross
September 6, 2006 at 8:04 pm[Rich Rubasch] “Also, if you have the firewire card installed in the AJ-1200A is there a second slot for the HD/SD SDI optional card as well, or is it an either/or.”
Dunno the answer to the first question, but as for this, you can have both firewire and HD SDI cards on this deck. I rent one that has both.
BTW, how is the Aurora treating you?
Shane
Littlefrog Post
http://www.lfhd.net -
Walter Biscardi
September 6, 2006 at 8:10 pmHDV to DVCPro HD is not an up-convert. It’s a codec change and no you can’t simply feed a firewire signal to the 1200A and expect it to convert the signal to DVCPro HD.
If you want the 1200A to record DVCPro HD, you need to feed it an HD-SDI signal.
There are two slots in the 1200A
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Rich Rubasch
September 6, 2006 at 10:26 pmBut the Sony can output 720p HD via firewire, and wouldn’t that be the correct frame size for DVCProHD and the Panasonic would simply write DVCProHD to the tape?
Guess I’m wrong on this one….but in Sony’s case, what is the 720p HD it can convert to?
Shane…the Pipe is doing great!
Rich Rubasch
Tilt Media -
Walter Biscardi
September 6, 2006 at 10:36 pm[Rich Rubasch] “But the Sony can output 720p HD via firewire, and wouldn’t that be the correct frame size for DVCProHD and the Panasonic would simply write DVCProHD to the tape?”
It will be HDV 720p going down Firewire, not DVCPro HD. The footage needs to be DVCPro HD before it gets to the 1200A or it will not be able to record anything. The 1200A Only records DVCPro HD via Firewire from a DVCPro HD source, such as an FCP timeline.
Frame size has nothing to do with it. It’s the wrong codec.
Kevin Monahan
September 7, 2006 at 12:28 amIf you want to convert HDV to DVCPro HD, you’re making a mistake. You’ll have worse picture quality, according to Nattress. And I believe him. He says to stay native HDV for the record.
Kevin Monahan
Take My FCP Master’s Workshop!
fcpworld.com
Pres. SF Cutters -
Shane Ross
September 7, 2006 at 12:34 amWell Kevin, it appears that there are two camps on this. Jerry Hofmann says that it is best to convert it to DVCPRO HD. Sure, there is a slight (very slight) quality hit, but working with the footage is 8x faster than HDV native. Faster in terms of rendering and prepping for various types of output. Plus the people at AJA recommend converting it to DVCPRO HD.
I happen to agree with them. But then again, I wouldn’t shoot HDV to begin with.
Shane
Littlefrog Post
Rich Rubasch
September 7, 2006 at 1:17 amOk, the client also wants to get an HDV clone of their source tape. So that would be a firewire camera to Sony HDV deck?
And if I did use the Sony deck via firewire into FCP coule I tell FCP to write the incoming Firewire stream to DVCPro HD and work with that on the timeline? Seems like that is a possible workflow into FCP if I want to cut everything DVCPro HD and have some HDV footage and the Sony deck.
Thanks for the dialog…
Rich Rubasch
Tilt Media -
Shane Ross
September 7, 2006 at 2:06 amSorry man, you can’t do that. The only way to capture HDV as DVCPRO HD is with a HD capture card. And darn Aurora isn’t designing one.
Shane
Littlefrog Post
Jeremy Garchow
September 7, 2006 at 2:43 amGraeme is a smart guy and I like what he does, but he also says there’s no reason to being in dv to another codec. While he may be right in a video sense (dv doesn’t suddenly look any better when digitized to 10 bit), I cannot agree with him from a timeline/graphics/color correction sense. Anything timeline finished in dv is much less quality than an uncompressed timeline. Since FCP can’t do multiple codecs in one timeline, I have to being in dv footage as uncompressed. I certainly don’t see a degradation. Mathematically and scientifically I think he’s proven there is one, but it’s a measurement that can’t be made to human eyes unless you stare and stare at certain parts of a frame and measure certain aspects of the signal. Now. Taking that into consideration, I’d certainly opt for an imperceptible degradation in transcoding to DVCPRO HD rather than wait 8 times longer to edit natively in HDV, but maybe that’s just me.
If Graeme is reading, please chime in.
Jeremy
Jeremy Garchow
September 7, 2006 at 2:46 amThe best way to get HDV to DVCPRO HD is get an AJA HD10AVA and an addenda lanc to RS-422 converter and feed your Kona/Blackmagic/1200A deck an HD SDI signal with embedded audio.
