Activity Forums VEGAS Pro OT – USB cam Cable Length? Need 50 feet or more
  • OT – USB cam Cable Length? Need 50 feet or more
    Posted by Will Standley on August 2, 2006 at 3:48 pm
    We need to set up 7 inexpensive cam’s in 7 office cubicals.
    (No computer in the cubical, only a small table & 2 chairs. Like a sales booth.)
    We hope to be able to use inexpensive off the shelf usb web cam’s.
    Cams will point down to the table to record what is written on a pad of paper… and we also need to record the conversation in the booth.
    1 – Can anyone suggest the best budget web cams to consider?
    2 – The booths are 5 ft wide and all in a row. We hope to plug all cams into one PC so the cable runs will be long.
    – How long can a USB cable be?
    – Can you get USB repeaters to extend the cable length?
    – What other solutions are there that we should take a look at?
    thanks for any help.
    Anoni Moose replied 20 years, 1 month ago 2 Members · 1 Reply
  • Anoni Moose
    August 3, 2006 at 12:47 am
    You can go upto 80 feed using ‘active’ cables that have built-in buffering (presumably powered by a powered connector at the computer end). One can connect up to five of the following cables which are 16 feet long each (which I think is near the limit for a single unbuffered cable). I personally use one of these, but have not chained them.
    https://tinyurl.com/fxb8b
