Activity Forums Apple Final Cut Pro Legacy OT: taping over and over and over old tape
  • OT: taping over and over and over old tape
    Posted by Jason Mccaffrey on July 27, 2005 at 6:09 pm
    I’m getting close to finishing up a project here. In order to show it to my boss I master it out to tape and hand it off to him. He comes back and tells me the changes. I make the changes and hand the new version back to him. Well, I’ve just been taping over the old version on the same tape. I’ve done this a few times now. I was just curious how many times one can do this without any adverse affects. I noticed on the last version the audio drifted out of sync by the end and was curious if this was from reusing this tape over and over, or if I have bigger fish to fry. Thanks for any feedback.
    Jason
    400 MHz Power Mac G4 2.9
    832 MB SDRAM
    (256 256 256 64=832-everyone asks)
    FCP 4.5
    QuickTime 6.5.2
    Bret Williams replied 21 years, 1 month ago 5 Members · 4 Replies
  • David Roth weiss
    July 27, 2005 at 6:28 pm
    Your sync issue is not caused by recording on a tape a few times, and thats especially if its a DV taoe, because its a digital recording. If you’re mastering to mini DV, obviously those tapes are tiny and fragile and prone to digital dropouts. Not a good idea to use them over and over again. The more robust tapes like digibeta and betaSP can be used quite a few times in a well maintained deck.
    DRW
  • Bryce Whiteside
    July 27, 2005 at 6:33 pm
    miniDV and DVCAM are fragile tape formats. I would use a new tape for your final/final/final/final/that’s a wrap final master.
    D-Beta and BetaSP are more robust and can be rerecorded on 10+ times or more, at least if you buy a premium brand of tape.
    HTH,
    Bryce
    Don’t worry Mr. B. I have a cunning plan…
    PowerBook 1.67 Ghz ATI 9700 128 MB 2 GB
    Final Cut Pro HD
    DVD Studio Pro 3
    Motion
  • Arnie Schlissel
    July 27, 2005 at 6:49 pm
    If you clean your heads as recommended by your deck’s manufacturer, you should be able to get 4 or 5 passes out of any decent quality DV tape before you start to see dropouts. But be safe & use a new tape for the final master.
    Arnie
    https://www.arniepix.com
  • Bret Williams
    July 27, 2005 at 7:32 pm
    I keep hearing this, but I can count the number of digital DV dropouts I’ve seen occur from overdubbing tapes on one hand. However I can’t even start to count how many dropouts I’ve see on a regular basis on betacam sp. On betacam, seems like the littlest amount of dust causes dropouts in both the cameras (especially) and then in the record/play heads in the deck.
    That whole world of editing around dropouts and trying to figure out where the dropout came from (cam, digitize, or record) just went away when I started using DV.
    DVCam tapes are supposed to be far superior in durability. But at 4-5 times the cost, is it worth it? The have nicer cases. 🙂
