Activity Forums VEGAS Pro OT: Ramifications of a system w/o a C: drive
  • OT: Ramifications of a system w/o a C: drive
    Posted by Barry Silverstein on August 19, 2005 at 1:19 pm
    I have been going through a bunch of system problems. The people who reset up my computer installed Windows XP Pro SP2 on my E: drive and there is no C: drive. I believe, even with no other programs installed besides windows, changing the designation to C: is not an option. So I need to know is having the system (windows) on a drive called E: and not having a C: drive problematic… especially as I reinstall my programs?
    Also:Is Windows backup and restore reliable?
    Barry
    James_j replied 21 years ago 5 Members · 4 Replies
  • Edward Troxel
    August 19, 2005 at 1:32 pm
    I see no reason why it would be a problem other than when people tell you something is at c:\program files\Sony\Vegas 6.0\Script Menu (for example) then you’ll have to remember to translate it to e:\….. instead.
    Edward Troxel
    JETDV Scripts
  • Glenn Delaune
    August 19, 2005 at 3:38 pm
    Hey Barry, the same thing happened to me last year, although I did it to myself by accident. My system ran just fine with no “C” drive assigned. I did however have a problem when trying to install a couple of programs but otherwise it was fine.
    Glenn
  • Chris Young
    August 19, 2005 at 4:06 pm
    Barry ~
    If you haven’t installed anything on the system yet I would throw it back at the people built it and get them to re-do the install as a default C:\ System drive.
    No doubt it will run okay but 99.9 percent of programs default to the C:\Program Files path and it’s a pain having to remember with every install/update that you have to redirect install paths, it
  • James_j
    August 20, 2005 at 5:54 pm
    This has been a ‘feature’ of the Windows OS since the beginning. If it sees any other drives during install, it gives them letters _before_ the system drive. 🙁
    But it makes no difference. Install paths should be checked carefully _anyway_. And few WinXP-era apps go to C: without asking. We’ve got several machines here that don’t have C: system drives, and it makes no functional day to day difference.
    I’d like to see Windows abandon the 24 drive letters anyway and use user definable labels.
