Activity › Forums › Apple Final Cut Pro Legacy › OT – Problems with Audio-out of my MBP
  • OT – Problems with Audio-out of my MBP
    Posted by Max Frank on October 4, 2010 at 9:00 am
    Hi there,
    I wonder if any of you have any ideas about this…
    I’m running a Macbook Pro 2.4 GHz Intel Core 2 Duo.
    I’ve got my speakers plugged into the mini-jack port.
    Lately, it seems as if the stereo output isn’t working properly – in fact, it sounds as if the audio coming out of my MBP is phasing – and in some cases, I’m losing the mids.
    I know this sounds weird.
    Any of you have any ideas or experience with this?
    Wayne
    Max Frank replied 15 years, 12 months ago 2 Members · 4 Replies
  • Adam Taylor
    October 4, 2010 at 12:01 pm
    my wife had a similar problem on an old G4 Powerbook…we found a cure searching the forums at apple, and if my memory is working, it was simply a case of dragging the file com.apple.soundpref.plist out from the root/library/preferences and dropping in the trash (dont empty until your sure this works)
    then restarting the laptop.The file should get rebuilt and if alls well sound might return. It certainly cured all the audio weirdness on our laptop…good luck
    rgds
    Adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
  • Max Frank
    October 4, 2010 at 1:03 pm
    Hi Adam,
    Thanks so much for your prompt and helpful response.
    I tried your suggestion – but my problem still persists.
    I’m beginning to wonder if this is hardware related.
    Thanks again,
    W
  • Adam Taylor
    October 4, 2010 at 1:08 pm
    another thought – have you checked the output with different speakers (and different cable)? Its possible the fault is not your mac, but the speakers.
    Adam Taylor
    Oldham, UK
  • Max Frank
    October 4, 2010 at 4:05 pm
    Yeah, this happens with any speakers/headphones I attach to the jack,
    Wayne
