Activity › Forums › Apple Final Cut Pro Legacy › OT: Instant SATA Access
Shane Ross
December 14, 2007 at 6:10 amNoo…works for me on both Tiger and Leopard. Hmmm…does the system profiler see the drive? How about the Disk Utility?
Shane
GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
http://www.lfhd.net -
Chi-ho Lee
December 14, 2007 at 1:05 pmNo. Disk Utility doesn’t see the drive. And Apple Profiler doesn’t see the unit as far as I can tell – what should it show up as in the profiler?
-CHL
Shane Ross
December 14, 2007 at 2:44 pmWhich one did you get? The one you mentioned on the first post?
https://www.geekstuff4u.com/product_info.php?manufacturers_id=&products_id=630
You might call their tech support. Or did you get something I recommended?
As long as the disk has power and is connected via USB, it should work. Make sure to try all the USB ports you have. YOu might also have gotten a bad unit. That happens.
Shane
Chi-ho Lee
December 14, 2007 at 8:17 pmHI Shane,
I got the cheapo one from geeks.com.
https://www.geeks.com/details.asp?invtid=2020-OTB
I suspect I have a bum unit. A friend has the same unit and it works fine on my MBP. They’re sending me another one. Thanks for the reply!
CHL
