Activity › Forums › Apple Final Cut Pro Legacy › OT: Instant SATA Access
Posted by Sean Oneil on October 19, 2007 at 4:54 pmCool product I saw on a blog today:
https://www.geekstuff4u.com/product_info.php?manufacturers_id=&products_id=630
Buying two of them now.
Chi-ho Lee replied 18 years, 9 months ago 6 Members · 14 Replies -
Shane Ross
October 19, 2007 at 5:25 pmPlease note…
$46 for the unit. $40 for the shipping!
$86 each…
I on the other hand have this…$19…
https://www.geeks.com/details.asp?invtid=2020-OTB&cpc=SCH
More cables…not as plug and play…but MAN…
Or…there’s always DROBO….www.drobo.com
Shane
Littlefrog Post
http://www.lfhd.net -
Chris Poisson
October 19, 2007 at 5:43 pmI don’t get the attraction, looks like only a USB connection.
Have a wonderful day.
Shane Ross
October 19, 2007 at 6:05 pmARCHIVING Chris…solely for archiving. USB 2 is plenty fast for that.
Not EVERY drive is used as media storage for editing…
Shane
Littlefrog Post
Sean Oneil
October 19, 2007 at 10:38 pmYeah this is for archiving. The thing that caught my attention is you don’t need to screw on some clunky drive trays. This is the first SATA enclosure I’ve seen where you just plug it in.
Shane, that Drobo thing looks awesome. I’m just wondering if data from Drobo drives can also be read by regular machines w/o the Drobo.
Warren Eig
October 20, 2007 at 5:37 amNo. The Drobo is proprietary. If the Drobo dies you ned a new one to read the data.
Warren
Warren Eig
O 310-470-0905
C 310-560-6245email: warren@babyboompictures.com
website: https://www.babyboompictures.comhttps://www.atomfilms.com/af/content/knitwits
https://www.atomfilms.com/film/family_xmas.jsp -
Shane Ross
October 20, 2007 at 5:45 amIt’ll work if you an eSATA Port Multiplier controller card. TONS of companies make them.
OH, BTW…I use this device to hook up my archival hard drives:
https://www.showtimepc.com/showtimepc/details.asp?item=ADA-EG-SAU2
Shane
Littlefrog Post
Aaron Zander
October 22, 2007 at 4:05 ammore than that
more and more drives are coming with internal sata connections. As a result, cases fail A LOT (maxtor, seagate I’m look at you) and it’s not really easy to find a single drive fw case with an internal sata set up at the local fry’s, but this set up (or more specifically the other sata/ide connector) can help get a project back on track for a day or 2, or recover a drive.
Sean Oneil
October 22, 2007 at 5:06 am[Shane Ross] “It’ll work if you an eSATA Port Multiplier controller card. TONS of companies make them.”
So you mean that you can use the Drobo software with any 1×5 SATA port multiplier?
Shane Ross
October 22, 2007 at 5:14 am[Sean ONeil] “So you mean that you can use the Drobo software with any 1×5 SATA port multiplier?”
No…I guess I misunderstood the question. I re-read the thread and I can’t for the life of me figure out what I was responding to.
No…if you build the raid on the DROBO, it only works on the Drobo. But why would you need it to work anywhere else? In case the Drobo dies?
Shane
Littlefrog Post
Chi-ho Lee
December 14, 2007 at 3:01 amShane,
I just got one of these USB/IDE/SATA adapter from Geeks.com but it’s not mounting the drives on my MBP. What are the specs of your machine that you’re hooking it up to? I’m on 10.5.1. I wonder if it’s an OS thing?
CHL
