Activity › Forums › Apple Final Cut Pro Legacy › OT: DCP transfer
  • OT: DCP transfer
    Posted by Alan Okey on September 15, 2008 at 9:03 pm
    I’m doing finishing work for a client who is entering her documentary in a myriad of festivals. The doc was shot on 29.97 interlaced DV, and I’m finishing it in 10-bit Uncompressed SD (there’s a fair amount of composited text and graphics that benefit from the 4:2:2 color space and lack of additional DV compression).
    Anyway, the client would like to submit her doc to the Academy of Motion Picture Arts and Sciences for consideration for an Academy Award (yeah, I know). The Academy accepts submissions on 35mm or 70mm film and DCP (Digital Cinema Profile) packages. The client would like to know how much it would cost to have her doc formatted for DCP projection. Setting aside the fact that SD video blown up to 2K will look atrocious, can anyone recommend a post facility that could perform the upconversion and DCP formatting? The client would like an answer as to pricing and technical feasibility. I would likely be supplying a DigiBeta or Uncompressed 10-bit Quicktime master to the post facility. I’m guessing that the quote will be well into five figures, but the client is a little naive and needs a dose of reality.
    Thanks in advance.
    Alan Okey replied 18 years ago 2 Members · 2 Replies
  • Bill Dewald
    September 15, 2008 at 11:05 pm
    try Fotokem in Burkbank, CA.
    Have you done color correction already? Its best to do that work after the upres – and will add to the price as well…
    But, if you _are_ going to spend the money, you should do it right – right?
  • Alan Okey
    September 15, 2008 at 11:17 pm
    [Bill Dewald] “Have you done color correction already? Its best to do that work after the upres – and will add to the price as well… “
    Yes, that’s mainly what I worked on, but I assumed that checking color (using a 3D LUT in mastering, etc.) was part of creating the DCP.
    [Bill Dewald] “But, if you _are_ going to spend the money, you should do it right – right?”
    Sure! Especially if it’s not my money…
