Activity Forums Apple OS X osx noob dmg/app questions
  • osx noob dmg/app questions
    Posted by Baba Goof on January 12, 2007 at 12:26 am
    i’ve just been downloading and installing some utilities and such
    and am not clear on the formats they appear in. some come as
    simple app files which open directly while others come as dmg’s
    which, while they also run without extraction, seem to require an
    extra mounting or extraction step. could someone point me to an
    explanation of the differences and whether there’s a way i can
    eliminate the extra step in the running of the dmg’s?
    thanks,
    BabaG
    Baba Goof replied 19 years, 8 months ago 2 Members · 2 Replies
  • Curtis Thompson
    January 12, 2007 at 12:38 am
    hello…
    a dmg is a disk image – think of it as a flash drive of a sort for your computer. if you get an app in a dmg, you should mount the dmg and then take the resulting app and install it on your hard drive (just drag it to your applications folder) and then “eject” (virtually) the dmg – you won’t need it any longer after that…
    make sense?
    sitruc
  • Baba Goof
    January 12, 2007 at 1:08 am
    got it! thanks!
