Activity › Forums › Adobe Premiere Pro › OSX Lion 10.7.4 WARNING!!!!!
Sebastián Grob plá replied 13 years, 9 months ago 9 Members · 23 Replies
Jeremy Garchow
May 10, 2012 at 6:28 pm[Thomas Smet] “No problems here either. In fact I don’t really notice anything faster or slower after the update.”
Do you guys have one of the two OpenCL cards that are approved by Adobe?
Thomas Smet
May 10, 2012 at 6:32 pmSure do.
17″ MBP 2.2Ghz
AMD 6750 1024MB
Works great for 30 to 60 minutes much faster then software mode then all of a sudden gpu mode plummets until I restart CS6. Software mode is flawless even if I switch to it from gpu mode after the gpu mode stops working after 30+ minutes.
Jeremy Garchow
May 10, 2012 at 7:40 pm[Thomas Smet] “Works great for 30 to 60 minutes much faster then software mode then all of a sudden gpu mode plummets until I restart CS6. Software mode is flawless even if I switch to it from gpu mode after the gpu mode stops working after 30+ minutes.”
You mean it literally switches after 30 minutes to software mode?
Thomas Smet
May 10, 2012 at 7:43 pmNo I mean after about 30 to 60 minutes the gpu performance falls off a cliff and even at 1/4 res I can only get every fourth frame for playback. If I manually change to the software mode it works fine after that. I can also save my project, shut down CS6 and open my project again and the gpu acceleration will work again for another 30 to 60 minutes. At that time I can rinse and repeat. Either switch to software mode or shut down CS6 and open again.
Morten
May 10, 2012 at 8:11 pmMight help to turn of Automatic Graphics Switching in Energy Saver
– No Parking Production –
2 x Finalcut Studio3, 2 x Prod. bundle CS5.5, 2 x MacPro, 2 x ioHD, Ethernet File Server w. X-Raid…. and FCPX on trial
Peter Garaway
May 11, 2012 at 3:43 amHi Thomas,
I wanted to let you know that we’re aware of this issue and working to resolve it. At this time we cannot commit to any timeframe.
I am curious if you have found steps to reproduce this issue or does it only occur after you your running Premiere for 30+mins?
Thanks for you feedback!
Peter Garaway
Adobe, Premiere Pro QE -
Thomas Smet
May 11, 2012 at 4:07 amThanks for the response.
Tonight I was able to run CS6 for well over 2 hours without the gpu mode failing. I was mostly doing cuts and some audio EQ. I was also leaving it sit there for awhile and running other apps like Chrome to see if I could kill it. The GPU kept going strong.
See this post for more info:
https://forums.creativecow.net/readpost/3/924646
Let me know if there are any other tests I could try or if you need any other info.
Peter Garaway
May 11, 2012 at 4:47 amSorry I just caught your post below.
Thanks for the details. I’m glad to hear things have been going smoother for you.
Peter Garaway
