Activity › Forums › Apple Final Cut Pro › “Original Media” in library package same as actual original media?
  • “Original Media” in library package same as actual original media?
    Posted by Jeff Feaz on March 30, 2018 at 2:37 am
    I use my libraries to store media. I noticed while unpacking a library in finder that the “Original Media” folder under each event contains .MOV files with the same names and sizes of my actual original media, which is .MP4 (from a Sony).
    My question is, are these transcoded, or just rewrapped? Would I be losing anything if I somehow lost the files from the camera and just had left what’s in the library package?
    Jeff Feaz replied 8 years, 6 months ago 3 Members · 4 Replies
  • Oliver Peters
    March 30, 2018 at 12:23 pm
    These could be rewrapped or transcoded, depending on the codec. Saying they are .MP4 is only part of the equation. Open one of these in QT Player and check the info. If it’s ProRes codec then they were transcoded. You should always separately back up your original camera files for archival purposes.
    – Oliver
    Oliver Peters – oliverpeters.com
  • Craig Alan
    April 2, 2018 at 6:19 am
    Oliver,
    I back up my media cards by dragging the two files that the computer picks up when the p2 card is connected to the computer.
    AVC-Intra 100 (1080p30), Linear PCM
    FCP X 10.4.
    There should be a left and right channels recorded using two different mikes.
    FC sees it as four tracks identical. or if stereo 2 identical wave forms.
    One of the two mikes is not seen by the iMac and the camera internal mikes are not picked up. Never had this in any other previous version of FCPX. I’m not using high sierra but rather 10.12.6. Does that mean anything?
    any advice?
    Imacs (i7); Canon 5D Mark III/70D, Panasonic HPX250P, FCP X 10.3, teach video production in L.A.
  • Oliver Peters
    April 2, 2018 at 12:18 pm
    Not sure what to tell you. Except that based on you original question, I believe FCPX rewraps these, because AVC-Intra is a supported codec.
    I would recommend Hedge as a more reliable back-up application for archiving your camera files.
    – Oliver
  • Jeff Feaz
    April 2, 2018 at 10:51 pm
    Thanks for info, Oliver.
