Activity › Forums › AJA Video Systems › Original IO problems
  • Original IO problems
    Posted by Annaël Beauchemin on January 17, 2010 at 9:52 pm
    I’m trying to hookup an older IO to a 2ghz G5 running FCP 6.0.5 on 10.5.5.
    The problem is that it displays only a still frame when I try to playback.
    Before I investigate deeper, has anyone been able to run an IO on 10.5 and FCP 6?
    Thanx!
    Annaël
    Annaël Beauchemin replied 16 years, 8 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    January 19, 2010 at 12:28 am
    Yes, but be sure to download the drivers and io control panel with firmware from aja.com/support
  • Michael Sacci
    January 19, 2010 at 4:37 am
    [Annaël Beauchemin] “The problem is that it displays only a still frame when I try to playback. “
    This is normally caused by having a mismatch of the video settings, the video out settings doesn’t match the sequence settings.
  • Annaël Beauchemin
    January 26, 2010 at 4:56 am
    thanx, that was it.
