Original Audio Track
Posted by Gary Buselt on August 29, 2009 at 2:56 pmWhen I add a mpg file to a project from my Sony HandyCam, the original audio that was recorded doesn’t import along with the video. What is it I’m not understanding?
-GB
PS Vegas v9.0a (Build 85)
Luis Cosme replied 17 years ago 3 Members · 3 Replies -
Mike Kujbida
August 29, 2009 at 3:14 pmIs this a miniDVD camcorder?
Did you import it using the File-Import-DVD Camcorder Disc option? -
Gary Buselt
August 31, 2009 at 10:34 amThanks for the response! I figured it out. The Sony format (MPG2) embeds the audio where Vegas won’t pull it in. Using Super C decoder, I converted the files to MPG4 format then Vegas gets it all.
-GB
Luis Cosme
September 7, 2009 at 3:27 pmI have another suggestion or just another way that may work for you without having to re-encode.
I have a sony hadndycam and don’t have to do all that.
In Windows, I highlight all the clips that are in the camera when it’s plugged in via usb,
then go to edit \ copy to folder \ and copy it to a folder on my external firewire that is plugged in to my laptop.Then when I open up vegas and go to the explorer I can drag and drop the files from my external hard drive right to the timeline and they work perfect.
My camera is a DCR-SR42 which records\creates MPEG-2 Files.
And the computer I’m using is a pc with vista 32-bitregards,
LouSinger,
Cinematographer/Editor
Music Composer/Producer
Graphic Animation
Panasonic HVX200A w Redrock M2e
Pro-Tools Engineer
Final Cut Pro Editor
Premiere Pro Editor
After Effects Artist
3d Studio Max
Pennsauken, New Jersey / Philadelphia area.
eMail: LRCProductions@gmail.com
