Activity Forums Adobe After Effects Orienting layer based on a vector.
  • Orienting layer based on a vector.
    Posted by Wouter Bruneel on November 21, 2009 at 3:19 am
    Hello everyone,
    Here’s what I’m up to. I’m making a stylized tree. All the leaves would be points on a sphere. So i have expression set for their coordinates based on the index of the layer to construct the leaves-sphere. that works well enough for the position of the leaves but i’m having trouble with the orientation. I want the leaves to be perpendicular to the vector from the origin of the sphere to the position point of the leave. I cant use auto-orient to a path since there is no motion path.
    Can anyone think of a way to make sure a layer is perpendicular to a given vector?
    thanks,
    Wouter
    Wouter Bruneel replied 16 years, 9 months ago 2 Members · 2 Replies
  • Dan Ebberts
    November 22, 2009 at 12:02 am
    Depending on how you define the center of your sphere, an orientation expression like this could work:
    center = [thisComp.width/2,thisComp.height/2,0];
    lookAt(toWorld(anchorPoint),center)
    Dan
  • Wouter Bruneel
    November 22, 2009 at 12:28 am
    Thanks dan,
    That solved it. I’ll have to figure out what it actually does but for now i’m happy to just copy paste it.
    thanks again,
    Wouter
