Activity Forums Maxon Cinema 4D Organizing Objects
  • Organizing Objects
    Posted by David Ormsby on June 20, 2005 at 5:40 pm
    Is there a way to alphabetize the list in the Object manager?
    I use Vectorworks, and when I import C4D seems to use the order of objects I added in VW, but it takes a bit of searching through the list to find what I need. Alphabetizing the tree would sure help, but I can’t find a way to do it.
    David Ormsby replied 21 years, 3 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    June 21, 2005 at 4:01 am
    No, unfortunately you can’t do that. Reason is that the order of objects/tags in the Object Manager plays an important role in setting priorities for animation. Do check out the search feature though (Object Manager>Objects>Search).
  • David Ormsby
    June 21, 2005 at 1:49 pm
    thanks Adam –
    I was guessing that was the case –
