organizing multicam clips within FC
I am developing a workflow importing and organizing a 3 camera shoot over multiple days and using P2 cams which each production day requires 2 cards per camera.
I have only one day’s practice shoot so far so I am not stuck yet with bad practices.
Some workflow questions.
I import clips from a custom named folder in the finder (a direct copy of each camera card)
and that data appears as the ‘camera name’ in list view.I want to assign a custom name to each clip because the original names are useless.
So I create a keyword collection for each cam from a day’s shoot.
I highlight clips I want to batch rename in browser>list view>start column.
In the inspector I am choosing edit>custom name with counter> and creating my custom name.
Now I don’t think it makes sense to save every custom name with counter because I have a lot of cards to organize and the custom window would get really full.
Does that makes sense or is there an easier way to go about this?
Also I forgot to save a copy of the defaults in this edit window and no longer have the default layouts.
Is there a way to reset to default?
Here is one keyword collection
TATI WA2 T1 12 based on talent name/wide angle card 1 or card 2 (since they are imported separately though with continuous timecode)/ T1 is take 1 (the first day of shooting the scene (these are improvised and there is only one take per session though we do pause production and clips will be heavily trimmed)/ 12 being the 12th clip in time order.
I’m finding the batch renaming tedious and was wondering if anyone has a workflow suggestion that might help before I get too deep into organizing this project.
Also when I go to use the multicam editor, since the cameras were paused at various times, what is the best way to sync them up? I’ve only done this with a continuous recording.
Do I sync it separately by section (at each pause) or can I make a compound clip out of each cam’s clips and sync them all at once? Will FC adjust the sync at difference points in the recording?
Since I am trimming this heavily and cutting a lot to b-roll it is not vital that I even cut using multicam. I could just find sections I want in the final edit and then choose the best angle to use though it needs to be synced with the camera that’s recording the feed from the mixer, rather than the internal mikes of the other two cams.
Mac Pro, macbook pro, Imacs (i7); Canon 5D Mark III/70D, Panasonic AG-HPX170/AG-HPX250P, Canon HV40, Sony Z7U/VX2000/PD170; FCP 6 certified; FCP X write professionally for a variety of media; teach video production in L.A.
