Activity › Forums › Apple Final Cut Pro › Order of keyer & mask matters (even if black on black)!
  • Order of keyer & mask matters (even if black on black)!
    Posted by Shea a.j. Comfort on July 13, 2012 at 8:33 pm
    Hello Everyone,
    I just learned something interesting and thought I’d share it with everyone in case it helps you avoid my problem!
    I was working with a clip that needed keying and a mask to cut out the sides:
    So, I added a mask, trimmed it to cut the sides out and was not happy to see the outline of the mask (which did translate when outputted):
    I thought maybe the feather control on the mask was too large and brought it to 0%, but there was still a faint outline that unfortunately did appear when outputted:
    I thought maybe the mask filtre was corrupted, so I re-loaded it a second time, but got the same results of the ghost outline of the filtre’s edges:
    Then I had a thought that maybe the order of the filtres would have an effect on the out come (even though it was black background and a blask mask…), so I rearranged the keyer filtre to above the mask filtre: Sure enough this worked and removed the mask filtre’s outline!:
    So, note to self: keyer THEN mask filter! Hopefully you can avoid this trap if you weren’t aware of it.
    Take care,
    Shea A.J. Comfort
    Shea a.j. Comfort replied 14 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
