Activity Forums Adobe After Effects Orbit Text Around Null With All 3 Axes Locked
  • Orbit Text Around Null With All 3 Axes Locked
    Posted by S.j. Deluise on August 26, 2010 at 3:04 pm
    I’m trying to accomplish the orbit effect of the nav menu on https://aescripts.com/
    I have a 3D text layer parented to a 3D null object. I’m using the following expression to lock the x-axis of the text as it orbits around the null.
    thisComp.layer(“Null 1”).transform.yRotation*-1;
    That works fine. However, using this expression for all 3 axes doesn’t work. I’d like the text’s XY and Z rotation to remain 0 as it orbits around the null, as the null’s XYZ values change simultaneously.
    S.j. Deluise replied 16 years, 1 month ago 35,269 Members · 1 Reply
  • S.j. Deluise
    August 26, 2010 at 6:09 pm
    Perfect! And no expressions necessary. Thank you!
