Activity Forums VEGAS Pro Optimizing Vegas 12 over multiple drives
  • Optimizing Vegas 12 over multiple drives
    Posted by Tim Riordan on December 19, 2014 at 7:36 pm
    Hi All,
    I have Vegas 12 64bit build 770, and am running Win 7 Ultimate. I am just adding a third HDD today and am wondering about optimizing Vegas across several drives. I have my OS and Vegas installed on a 120Gb SSD. I keep my .veg project files and all media on a WD Black drive, and also have my Prerender and Temp file folders on the same HDD as the media, and I render to that drive as well. As I’m adding another 3Tb Black drive today, I’m wondering if there is any advantage to keeping .veg project files and directories on one drive and all project media on another, or just using one as a render drive? So a potential setup would looks something like: OS and Vegas program on the SSD; .veg and directories on one HDD; and all project media on another HDD. The setup I have to this point is pretty much rock solid for stability. But I’m looking for performance tweaks. I’m curious what others do?
    Tim
    John Rofrano replied 11 years, 9 months ago 6 Members · 23 Replies
  • 23 Replies
  • Mike Kujbida
    December 19, 2014 at 7:45 pm
    I prefer to keep all related project material in a single master folder. This is the way I’ve always done it and it works for me as well as making backups much easier.
    When I start a new project, I create a master folder under that name. In that master folder are various subfolders such as Project Files, Graphics, Audio, Raw Footage, Renders and whatever else is needed.
    If the music or graphics exist elsewhere on my drive, I make a copy of it/them for the project. That way everything is all in one place.
  • Tim Riordan
    December 19, 2014 at 8:13 pm
    Thanks for the input Mike. In terms of organizing the project that seems really sensible and I do similar for the media. But I’m more curious about situations where you have multiple drives as mentioned in the op, and the arrangement of .veg project files, the Temp, Prerender and Render folders and then the media itself. Is there any advantage in terms of speed or even more stability when distributing said items (not the individual project media) across multiple drives?
  • Mike Kujbida
    December 19, 2014 at 8:19 pm
    Tim, I wish I could answer your question but I’ve always done things the way I describe so I have no idea if your way would add speed or stability. Hopefully other users will jump in here and offer their experiences.
  • John Rofrano
    December 19, 2014 at 9:28 pm
    I keep all of my project media in a single folder just like Mike does. This makes it very easy to archive when the project is done because the folder is self-contained. I have a setup with three drives with an SSD boot drive for OS and applications, 3TB WD Green drive with stock media (stock footage, digital juice files, ACID Loops, etc.) and then a third drive for my projects. (in the past I’ve used a RAID 0 but now I use a RAID 5 for my video editing drive). I’ve never had a separate “render” drive because renders have always been CPU/GPU bound since I started cutting HD.
    I guess you could use the extra drive for rendering so that the source is on one drive and the target is on the other but this will only improve performance if disk I/O is the bottleneck in your system. If not, you are wasting your time worrying about it.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Tim Riordan
    December 19, 2014 at 10:06 pm
    Thanks John, that is exactly the kind of info I was looking for. Based on that answer I think the setup I have is already pretty optimized, and I won’t worry about adding the extra drive into the Vegas mix. It becomes more internal archived storage. My backups are to USB drives. Thanks for taking the time to answer.
  • John Rofrano
    December 20, 2014 at 1:36 am
    My pleasure Tim, glad I could help.
    ~jr
  • Nigel O’neill
    December 20, 2014 at 11:16 pm
    Hmmm … I wonder if anyone on this forum has an SSD only setup. I have been considering it, and with prices starting to come down to around $500 for a 1 TB drive, would it give that last bit of performance boost for an aging 1st gen i7 setup such as mine?
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 12 (x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
  • John Rofrano
    December 21, 2014 at 12:46 am
    [Nigel O'Neill] “would it give that last bit of performance boost for an aging 1st gen i7 setup such as mine?”
    It depends on how old your motherboard is. If you have SATA II your 6GB/s SSD will be limited by the 3GB/s SATA II bus speed and will only get 1/2 the throughput as SATA III. I added an SSD boot drive to my 6 ear old 2008 Mac Pro 8-Core w/SATA II and it definitely made it feel like a new computer. You don’t realize how I/O bound the OS is until you get an SSD. So there are benefits.
    My 2012 Mac Pro is also limited by a SATA II bus and the 3 disc RAID 5 on my Apple RAID card is almost as fast as my SSD because at some point you saturate the 3GB/s SATA II bus and nothing is going to go faster. Then I added an OWC Mercury Accelsior_E2 PCI Express SSD and now I’m getting twice the throughout on that SSD because it’s 6GB/s SATA III and it also has two eSATA ports so my external eSATA enclosure is actually faster then my internal drives.
    So breathing life into an old computer with an SSD is definitely worthwhile but how much life you get depends on whether your motherboard is SATA II or SATA III.
    ~jr
  • Nigel O’neill
    December 21, 2014 at 3:10 am
    Thanks John. A comprehensive response, as always. My system only supports SATA II. The Mercury Accelsior looks interesting/tempting, but I have a sneaking suspicion my PCI Express slot is taken by my USB 3 card. My Video card takes up 2 slots and there is only 1 slot left. Will have to consult the manual to see what’s left.
  • John Rofrano
    December 21, 2014 at 4:23 am
    [Nigel O'Neill] “Will have to consult the manual to see what’s left.”
    The Mercury Accelsior should be in a 4x slot to get full bandwidth. If you put it in a 2x slot it will work but at 1/2 the speed so it’s not worth it at that point. I use it as a boot drive and it’s scary fast.
    ~jr
Page 1 of 3
