Activity Forums Adobe After Effects optimal workflow settings from PS to AE to FCP (for HD video)
  • optimal workflow settings from PS to AE to FCP (for HD video)
    Posted by Christian Svanes on March 15, 2010 at 3:26 pm
    i’ve been reading through many of the posts here at the forum, which have been very helpful, but i’m still unclear about what might be the best way to establish a work flow from graphic images that i create in photoshop, to after effects, where they are animated and then imported into final cut pro, where they are merged with video footage to create the final piece.
    though i’m using three different applications to create an HD video piece, i believe that the main area of concern lies in after effects, which is why i’m posting this question here.
    once in fcp, i’ve often experienced that the text is quite pixelated, which i have been able to resolve (thanks to help in these forums), but i still find that the text is never as crisp and clear as i would have liked. despite working out issues in regard to field dominance, there remains a bit of undesired fuzziness around the images. there’s a link to the almost finished video work towards the bottom of this post.
    at present, here is my workflow:
    (1) i create a multilayered .psd file in photoshop (CS4), for which the settings are: rgb colors/ 300 dpi / 8 bits/channel / the image dimensions are: 2610 x 774 (resample image setting is at bicubic). there are 24 layers to the image.
    (2) this image is imported to after effects (CS4). the settings for my composition are: preset HDV/HDTV 720 29.97 / 1280 x 720 / square pixels / 29.97 fp / full resolution.
    (3) the images are resized (down) then animated – most of them are simple repositions, so that the text moves across the screen at various speeds.
    (4) this composition is exported, using the Add to Render Queue command, which is then rendered as lossless with alpha channel, generating a .mov file
    (5) the .mov file is imported to FCP (5.1.4), where the FCP sequence settings match the AE composition settings. the FCP sequence field dominance is set to none.
    (6) from fcp, i export using compressor, again matching up the settings, same dimensions (aspect ratio) using these pre-sets for HD video: H.264 compressor / data rate restricted to 5000 kbits/sec. the frame control settings are on, with the following options: resize filter set to BETTER; output fields set to PROGRESSIVE; deinterlace set to BETTER (motion adaptive)…
    the end result is not bad, but it’s fairly fuzzy around the text.
    here’s a link to an example of such fuzziness – the film is non-HD, uploaded to vimeo, but the end results are the same – it’s a work that i posted yesterday – and i’m presently working on the HD version of this piece: https://www.vimeo.com/10151957
    is there something that i am not doing quite right? that seems evident, yes? any advice for a newbie like me would be greatly appreciated.
    one thing that i have yet to gain a full understanding of, is how de-interlacing or interlacing affects the final result. i’m doing my research on this, but any clarifications are welcome.
    thank you everyone.
    sincerely,
    christian
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Christian Svanes replied 16 years, 5 months ago 2 Members · 2 Replies
  • Todd Kopriva
    March 15, 2010 at 5:53 pm
    There are some tips for working with text and other vector graphics in the context of compressed video here:
    “Best practices for creating text and vector graphics for video”.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Christian Svanes
    March 15, 2010 at 9:15 pm
    thank you, to both of you.
    regarding the idea of doing all of the work in AE, i’ll see what i can do to improve my AE skills. i like doing my edits in FCP, but if i can edit just as easily in AE, then yeah, that makes a lot of sense.
