Activity › Forums › Apple Final Cut Pro Legacy › Optimal settings in FCP when destination is DVDSP?
  • Chris Borjis
    January 6, 2009 at 11:10 pm
    ProRes
  • Walter Biscardi
    January 7, 2009 at 12:49 pm
    DVCPro 25 is just fine. Just export as “Current Settings” and turn your quality way up in Compressor.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Mark Suszko
    January 7, 2009 at 3:43 pm
    Thanks, Walter. Any final details in that regard?
  • Walter Biscardi
    January 7, 2009 at 3:55 pm
    [Mark Suszko] “Thanks, Walter. Any final details in that regard?”
    Make sure your field order is correct and turn the quality sliders up as far as you feel comfortable. Start with the High Quality 90 minute DVD settings and go into the controls and turn up the quality. If you have a DVD-RW around, those are great so you can burn some test DVDs for quality tests. Sometimes if you go too far on the quality settings the disc will skip and stutter so you just dial back a bit until you get optimal quality and optimal playback.
    Personally we use BitVice when we want absolute maximum quality on a DVD. The quality of those MPEG-2 files are superior to Compressor, even using Compressor’s highest quality settings. And it takes advantage of all 8 cores on the Mac without needing to invoke QMaster.
    Read my Blog!
  • Chris Borjis
    January 7, 2009 at 5:48 pm
    [walter biscardi] “DVCPro 25 is fine”
    you don’t see artifacts with titles doing it that way?
    I figure thats too close to DV compression to take a chance.
