Activity Forums Adobe After Effects Optimal setting for MacBook Pro
  • Optimal setting for MacBook Pro
    Posted by Justin Skotarczyk on March 6, 2008 at 2:56 pm
    Hi guys,
    I just upgraded my MacBook Pro(2.2GHz Intel Core 2 Duo, 120GB HD) to 4GB of RAM to aid my renders in AE, and so far I am unimpressed with the results.
    I know AE can only utilize 3GB RAM currently, but I am looking for advice from users that run AE on a notebook to see what preference settings really help maximize the use of RAM.
    Any suggestions??
    Kent St. john replied 17 years, 6 months ago 3 Members · 2 Replies
  • Darby Edelen
    March 6, 2008 at 7:52 pm
    [Justin Sko] “I just upgraded my MacBook Pro(2.2GHz Intel Core 2 Duo, 120GB HD) to 4GB of RAM to aid my renders in AE, and so far I am unimpressed with the results.”
    Try turning on multiprocessing in the preferences and tweaking your Memory & Cache settings.
    Here would be my recommended settings (you may want to play with this a bit):
    Memory & Cache:
    Maximum Memory Usage: 120% (Never set this above 140%, the 120% default seems good)
    Maximum RAM Cache Size: 50% (Believe it or not, smaller values are often better here… not too small though)
    Enable Disk Cache: On (this isn’t really all that necessary)
    Maximum Disk Cache Size: 2000MB – 4000MB (if its enabled, you can change this to a higher value if you have the space, but it probably won’t be used. Its not recommended to use less than 2000MB)
    Multiprocessing:
    Render Multiple Frames Simultaneously: On
    Darby Edelen
    Designer
    Left Coast Digital
    Santa Cruz, CA
  • Kent St. john
    March 20, 2009 at 4:16 pm
    I’m running a MacBook Pro also (Intel Core Duo 2.16GHz), however only have 2GB of RAM. Will the same settings listed above work for me as well?
    -Kent
