Activity Forums VEGAS Pro Optimal file size for web
  • Optimal file size for web
    Posted by Ron Whitaker on August 15, 2012 at 8:01 pm
    Does anyone have a suggested file size range if you want to put a video project to be viewed online?
    I have some training-type videos I’ve created. When I export them to MP4 using the MainConcept AVC/AAC(*.mp4) format from SVP 11, their sizes range from 93.4MB to 208MB. I have Enable progressive download checked.
    What I do then is open them in a freebie I downloaded called MPEG Streamclip and then compress.
    Is that advisable for videos that you eventually want to put up on the web (not necessarily YouTube)?
    Nigel O’neill replied 14 years, 1 month ago 3 Members · 2 Replies
  • Michael Acres
    August 16, 2012 at 7:26 am
    end file size depend on if it is HD and length
    SVP10 & 11 have internet recommended options under the sony mp4 menu and i would use those. you can further compress by going into the custom options and lowering the bitrate.
    I have found that 720p hd footage looks decent at 4mbps and the default is 8mbps
  • Nigel O’neill
    Ron
    In this day and age of fast broadband/ADSL/cable Internet download speeds, 100 to 200 mb is no longer the big ask it used to be. If you said to me that 200 mb was for a 30 second video I would be concerned as you should be able to fit at least 10 minutes of decent quality mp4 video in that space.
    My system specs: Intel i7 970, 12GB RAM, ASUS P6T, Vegas Pro 11 (x32/x64), Windows 7 x64 Ultimate, Vegas Production Assistant 1.0, VASST Ultimate S Pro 4.1, Neat Video Pro 2.6
