Activity Forums Adobe Premiere Pro Optimal Adobe Premiere CS3 Export to Encore settings
  • Optimal Adobe Premiere CS3 Export to Encore settings
    Posted by Stal Lionne on September 11, 2008 at 9:53 am
    Hi, I am very new to Adobe Premiere CS3 and Encore CS3. I have a 2hr dance video broken into about 28 clips. I am trying to create a DVD from the videos with simple menus and titles.
    Full requirements:
    (1) Produce 2hrs of video in either 1 double-layer DVD or 2 single layer DVD in NTSC format
    (2) Add titles for each video clip (28 total to introduce each dance clip)
    (3) Add menu/chapter selections for each video clip so viewers can jump to a dance show of their choice (maybe 28 chapters since each video is at most 5 min long)
    (4) The source file was shot in HD (16:9), and captured as .m2t files.
    Video: MPEG2 Video 1440×1080 (16:9) 29.97fps 25000Kbps
    Audio: MPEG Audio 48000Hz stereo 384Kbps
    (5)This is a low budget production, so I can’t really afford the pro help.
    (6) I have successfully created sequences, titles and chapters for the videos in AP CS3. I now need to export to Encore to do Menu stuff before burning a master copy to be duplicated.
    QUESTION:
    Based on the factors above, please could someone suggest the optimal settings for exporting the video? I don’t mind taking the video down to 4:3 aspect ratio or SD, as long as it has reasonable viewing quality and no distortions.
    I tried rendering 4 min of the clip in HD with High quality settings just to see the output. Gosh, was I stupid! It is taking 10hrs to render a 4 min video? And I have 6hrs total of video to make in less than a week. Please help.
    Stal
    Jeff Pulera replied 17 years, 11 months ago 3 Members · 8 Replies
  • 8 Replies
  • Mike Velte
    September 11, 2008 at 12:48 pm
    Compressing HDV down to SD is going to take forever without 2 Quad core processors. Further the resulting quality is poor compared to shooting in SD.
    You could have down-converted in the camera at capture in real time.
    Putting 2 hours of dancing on a single sided DVD at 4200 kbps is going to produce mediocre results. Dual layer at 7000 kbps will produce much better results, but dual layer discs have compatibility issues.
    Encoding 16:9 widescreen footage creates other issues…many DVD players require the user to choose the Aspect ratio on their DVD remote, resulting in customer complaints of squishing.
    Other challenges you face involves HDV low light capabilities. Very poor compared to say a VX2100.
  • Jeff Pulera
    September 11, 2008 at 2:26 pm
    Hi Stal,
    I do a lot of dance recitals and can offer some tips. As Mike said, you’d have been better off downconverting from the camera and simply editing in Widescreen DV. Not much to be done about that at this point. Adobe does a poor job of encoding HDV to MPEG-2 for DVD, the results may be flickery. You won’t go to 4:3, just make 16:9 DVDs.
    It sounds like you are trying to do each dance segment as a separate clip? I would put it all on one timeline, and simply add chapter marks at the beginning of each dance. Much less work, and the viewer can then watch the entire program straight through rather than having to watch each segment one at a time. They can still jump to any chapter using the chapter marks you set, whether from a menu or just using the “Next” button on the remote.
    In other words, don’t encode 28 different MPEG-2 clips and try and assemble them into a DVD if that was your intention. Create a single, 2-hr. clip with 28 chapter marks in it.
    At 2 hours, you can encode using CBR 4500 encode settings. Encore should convert audio to AC-3 Dolby automatically so this will fit a single 4.7GB DVD.
    When starting with DV footage, the DVD would come out pretty good at these settings. Coming from HDV, the conversion is going to hurt quality unfortunately. Maybe a third-party encoder like TMPGEnc would do a better job with that
    Good luck with the project
    Jeff Pulera
    Safe Harbor Computers
    http://www.sharbor.com
  • Stal Lionne
    September 11, 2008 at 10:47 pm
    Hi Jeff and Mike, thanks for your inputs. As you can see, the source format is water over the bridge as I can’t go back an reshoot (basically, I got a vidoegrapher to shoot the scenes, and now he is sick an unable to produce the video, so I am stuck with the raw formats with screaming mothers wanting to see the videos of their kids dancing 🙂
    Ok. So I need a solution. So far here’s what I gather from your inputs.
    (1) Use one timeline to build video. (Was already doing it that way 🙂
    (2) Produce the DVD in wide screen 1440×1080(16:9), progressive 29.97fps @ 7Mbps or 4.5Mbps?
    (3) Compress using CBR 4500 (not sure what this is. I don’t mind using 2 single disks if this would help quality)
    Also, I tried different outputs after my 10 hrs debacle (which didn’t look good), but I have this problem: The source video fits nicely in AP CS3 source view window (and all the media players I tested it with). But in the program window + encoded output, the video is magnified and cutting out footage. So I tried to scale down the clip to almost 49%. That is terrible as I think any resizing of the frames is going to hurt my quality and render time. What’s up with my settings to cause this? If I am going to do wide screen I would like the video to come out taking up the same safe margins, instead of expanding out of the safe margins. I can provide a screen capture if that would help you see my dilema.
    Thanks again,
    Stal
  • Stal Lionne
    September 11, 2008 at 10:58 pm
    More info:
    Please can you tell, based on my published source formats in main thread, which of these settings would give me a reasonably quality video output at a reasonable render time.
    (A)
    General
    Editing mode: HDV 1080p
    Timebase: 25.00 fps
    Video Settings
    Frame size: 1440h 1080v (1.333)
    Frame rate: 25.00 frames/second
    Pixel Aspect Ratio: HD Anamorphic 1080 (1.333)
    Fields: No Fields (Progressive Scan)
    Audio Settings
    Sample rate: 48000 samples/second
    Capture Format
    HDV Capture
    Video Rendering
    Maximum Bit Depth: Off
    Preview File Format: I-Frame only MPEG-2
    Compressor: I-Frame Only MPEG
    Color depth: Millions of colors
    (B)
    General
    Editing mode: HDV 1080i
    Timebase: 29.97 fps
    Video Settings
    Frame rate: 29.97 frames/second
    Fields: Upper Field First
    Audio Settings
    Capture Format
    HDV Capture
    Video Rendering
    Stal
  • Mike Velte
    September 12, 2008 at 10:44 am
    A 2 DVD set would allow for better quality than a single DVD.
    Set up a Widescreen DV NTSC Project. Choose Edit>Preferences>General and deselect “Default scale to frame size”. Import your 1440×1080 footage and scale to 40%. 40% will keep all the action within the action safe zone.
    Edit and then export. Format= Mpeg 2 DVD, Range = Entire sequence, Preset= NTSC Widescreen Medium Quality. Change “Bitrate Encoding” to CBR. Change “Bitrate” to 7.5 Mbps. Cook until done.
  • Jeff Pulera
    September 12, 2008 at 2:42 pm
    While a 2-DVD set will obviously provide “optimum quality”, this is not necessary. I have been delivering 2+ hour weddings, dance recitals and stage events on DVD since 2000 and have never had a quality complaint using the 4500 CBR encoding (or less even).
    2-DVD sets equal double the setup, rendering, duplication, materials and is also an inconvenience to the customer to have to change discs to see the whole program.
    I’m not saying NEVER do 2 discs, can be OK for a wedding with a couple copies, but for recitals or other high-volume jobs, seldom worth it. I just sent out a 135-minute recital on one DVD and this is common for me, parents love them, never a complaint about quality or content.
    While the suggestion of putting the video into a DV widescreen project will work, it could literally take days to render a 2-hour video, it is incredibly slow that way.
    Back to your question about encoding settings, the 1440×1080 settings are for Blu-ray. In the Encoder, you will want to choose “MPEG-2 for DVD” and choose an NTSC preset and be sure to check the “16:9” box for widescreen, and then you can alter the encoding rate to 4500 CBR.
    Perhaps if you check the “Deinterlace” button in the encoder this will get rid of the nasty flickers that happen when encoding HDV to DVD, try a short sample perhaps. This would result in a “progressive scan” look to the video.
    There is another option that might possibly work for you, IF you have access to the HDV camcorder. Break the completed timeline into two one-hour segments and export each to HDV tape.
    Then set the camera to downconvert and capture the footage into a DV widescreen project. This way, the camera is doing the HD > SD conversion. Put the captured clips together on one timeline, THEN export to DVD, 4500CBR widescreen.
    I wish I had better news for you, we are all struggling with HD workflows though.
    Jeff
  • Stal Lionne
    September 18, 2008 at 8:49 am
    Thanks guys…you have been very helpful.
    So, when creating the project, do I start with HDV 1080p or HDV 1080i or NTSC DV Widescreen 48KHz? I am trying to test each projecct settings combination with the final encoding settings…too many permutations in the time I have…Even a small 2 min clip for testing is taking quite a while to encode burn, run to the TV and repeat…
    Stal
  • Jeff Pulera
    September 18, 2008 at 1:57 pm
    Hi Stal,
    Premiere project settings should match your source video, i.e. HDV 1080i
    Jeff
