Activity › Forums › Apple Final Cut Pro › Optical Mess
  • Optical Mess
    Posted by Eric Santiago on July 4, 2012 at 9:28 pm
    Probably my first beef ever about this app.
    I have brought this up before on others posts but I have to start my own.
    This is the third project Ive had to use Optical Flow.
    Its seems to be bunk when I use it.
    Ive had major problems with snowboarding videos, then some basic motions and now I have a close to static shot of trees and my camera moves maybe for a few seconds.
    Im still get that warpy messy look on the screen.
    I have to avoid and use Frame Blending which isnt that great.
    Oliver Peters replied 14 years, 2 months ago 2 Members · 5 Replies
  • Oliver Peters
    July 4, 2012 at 11:35 pm
    This is all normal for any optical flow process. It’s entirely dependent on colors, contrast, detail in the background and horizontal camera motion. Some shots are great and others a mess. If you want something with a little more control, buy the Twixtor plug-in. But, it will not be perfect, either.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Eric Santiago
    July 5, 2012 at 12:20 am
    Thanks Oliver. Yes we have Twixtor on Avid at work and that too can get messy.
    I guess next time shoot this stuff with a Phantom 😉
  • Oliver Peters
    July 5, 2012 at 1:07 am
    [Eric Santiago] “I guess next time shoot this stuff with a Phantom ;)”
    The last job like this I worked on, we had the DP shoot everything with Alexa at 120fps. “Normal time” footage was sped up 5x to achieve 24fps (with sync sound) and a few shots were slowed even more via Twixtor to the equivalent of 1200fps.
    – Oliver
    Orlando, FL
  • Eric Santiago
    July 5, 2012 at 3:35 pm
    Oliver how was the results using Optical Flow?
  • Oliver Peters
    July 5, 2012 at 7:51 pm
    [Eric Santiago] “Oliver how was the results using Optical Flow?”
    More artifacts than Twixtor. Mainly more apparent image stretching/morphing in the part of the image that I needed to keep clean. I ended up doing the final effects with Twixtor in AE. The other speed-ups (120 x 5 = 24fps) didn’t require optical flow.
    – Oliver
    Orlando, FL
