Activity Forums Apple Motion Optical flow retiming loses clip interlacing
  • Optical flow retiming loses clip interlacing
    Posted by Paul Escandon on May 1, 2008 at 5:21 pm
    So I sent a DVCPRO HD 1080i clip in a DVCPRO HD 1080i timeline from Final Cut to Motion 3 to retime it to 50%. I performed this retiming using optical flow and when I saved and rendered the motion clip in Final Cut – the interlacing was gone. Checking back in motion – I see that the interlacing appears to still be there after the retiming has occurred.
    What am I doing wrong here? Or is this a limitation of Motion’s optical flow retiming that I wasn’t aware of? I’m not rendering out the file from Motion 3 – I’m just saving the project and rendering the embedded .motn clip back in FCP.
    Thanks.
    Paul Escandon
    Producer | Director – Oremus Productions
    oremusproductions.com |
    Tom Brooks replied 17 years, 10 months ago 2 Members · 1 Reply
  • Tom Brooks
    November 2, 2008 at 2:37 pm
    Did you try setting rendering of Motion projects to Best in your FCP sequence settings? Normal setting doesn’t seem to get you certain properties from Motion.
