Activity Forums Adobe After Effects Optical Flares not showing up render !!??
  • Optical Flares not showing up render !!??
    Posted by Stan Fraser on January 28, 2015 at 6:34 pm
    I am working to a deadline on friday but cannot find a solution to an problem I am having with the plugin Optical Flares…
    I am working on a fairly big composition of a galaxy which a mixture of 2D and 3D objects. I have added two Optical Flare effects as they look really nice and give the animation some realism. However, when I go to render the comp, it only renders the Optical Flares and nothing else. Furthermore when I make Optical Flares invisible, everything is comes up on the render again. I tried precomposing just the optical flares in the composition, however this has the effect of one of the flares showing up and the other not!!??
    As you can imagine I am really confused.. Any help would be massively appreciated!
    Best
    Stanley
    Walter Soyka replied 11 years, 7 months ago 2 Members · 1 Reply
  • Walter Soyka
    January 29, 2015 at 3:40 pm
    Can you post a screenshot of your entire After Effects UI, including the viewer panel and the timeline, where you are having the problem?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
