Activity Forums Adobe After Effects Optical Flares does not appear!
  • Optical Flares does not appear!
    Posted by Bogdan Lucian on January 13, 2011 at 9:55 am
    Hey everyone !
    I’m new on creativecow.net and i hope to get some help in my problem with Optical Flare from Videocopilot.
    When OF is applied to a layer, black solid layer, nothing happens in my Composition window, no lens flare. I set the Render Mode to Transparent, all options, and nothing. In options of the OF, i see the lens flare, i can adjust all properties like i want, but in my Composition windows nothing happens.
    So, if anyone can help me, i would appreciate.
    PS: I reinstalled After Effects, and still nothing.
    Irfan Khalid replied 10 years, 11 months ago 8 Members · 13 Replies
  • 13 Replies
  • Jason Mettler
    January 13, 2011 at 9:59 pm
    Is the little ‘fx’ on/off toggle box showing up by the words ‘Optical Flares’ in the Effects Panel?
  • Bogdan Lucian
    January 14, 2011 at 7:38 am
    Hey Jasson. Yes, everything is on :). take a look here https://screencast.com/t/FUnQljVUZ
  • Jason Mettler
    January 14, 2011 at 4:37 pm
    Hmm…from the screenshot I can’t see any problem. Are you running CS5? The video copilot forums has other people with what sounds like the same problem using CS5.
  • Bogdan Lucian
    January 14, 2011 at 5:12 pm
    yes, i’m working in cs5 and before to reinstall my windows the plugin works very good. i installed on another PC, and it didn’t work. i think the plugin is problem. very strange. on the forum I found someone who had the same problem, but with no happy ending :). I think i will fix it. Thanks for your time. I’ll come up with a solution.
  • Julia Schmid
    July 28, 2011 at 2:41 pm
    Did you find a solution? I have the same problem in CS5. Cheers, Julia
  • Bogdan Lucian
    July 28, 2011 at 7:36 pm
    Hey! Honestly i’m trying to remember how i fixed that problem. I’m 99% sure that was a problem with my plugin. I wanted to copy the plugin to my pc, from another pc. I hope it does make sense for you.
  • Rebekka Deforce
    May 9, 2012 at 11:01 am
    I have the same problem. Anybody has an idea on how to fix it? THX!
  • Bogdan Lucian
    May 9, 2012 at 11:46 am
    Hey !
    I wish I can remember how I fixed the problem with OF, but I can’t. I think I deleted the OF from AE Plugins folder, and I tried again to install it. Before that AE was re-installed, but the OF still didn’t work.
    Just remove your OF and re-install it again, maybe delete all your AE cache.
    Sorry I can’t remember. Good luck!
  • Rebekka Deforce
    May 9, 2012 at 2:00 pm
    Thx! 🙁
  • Ciearon Matthews
    May 20, 2012 at 6:01 pm
    have you tried putting the optical flare on a adjustment layer and setting the mode to screen?
