Activity › Forums › Adobe After Effects › Optical Flares does not appear!
Cal Mcguffie
August 19, 2012 at 11:40 pmHas anyone figured it out? I just installed the Optical Flares plug in and I am having the same problem.
Ajmal Ashraf
August 23, 2012 at 12:32 pmI think you guyz are using the 32 bit version of Optical Flares. AE CS5 and above is a 64 bit software. Check on that.
T0X1C
Irfan Khalid
September 2, 2015 at 4:49 pmGUYS
i had a same problem , want to help out u guysgo to the link and download this update first .
https://www.videocopilot.net/products/opticalflares/update/it will ask you to generate license ,
get the license generator from the google kickassand copy and paste in after effect plugin/optical flare folder
thanks ..
