Activity › Forums › Apple Final Cut Pro Legacy › Optical Bay Hard Drive
  • Optical Bay Hard Drive
    Posted by Nate Stephens on July 2, 2008 at 2:17 am
    Hey folks, Just got my new Mac Pro (finally) and I am loading it up with Western Digital TB drives ($169 each- had to get 4) I was amazed at how easy it was to load 3 of the drives and when I tried to mount one in the second optical bay, I noticed that it takes some rigging or maybe a cage.. Not as straight forward as the old G4…. easier to get to, but not as obvious to mount the drive….
    So is there a cage or a secret mounting technique somebody has discovered that they could share…
    I am thinking about making a cage out of old PC parts,,, but there must be a simple route to this, after all it is a Mac…
    Walter Biscardi replied 18 years, 3 months ago 4 Members · 6 Replies
  • David Roth weiss
    July 2, 2008 at 2:34 am
    https://www.barefeats.com/hard87.html
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Nate Stephens
    July 2, 2008 at 10:02 am
    Thanks David,
    I knew it was out there somewhere. That is what I like about the COW…. Somebody always remembers the “inventory” better than you… So just “COW IT” and go to bed….. Why stay up for another 4 hours…
    I was planning on buying the memory from Transintl also… I just needed to check the accounts before I over spend the bank.. Didn’t know they had the “sled”…. thanks for the tip
    So what is the value to 16 over 8 over 4 gigs of ram on the 3.2 Octo core?
    Wally B. always suggest 4 gigs.. But he did say he was getting a new 3.2 so I wonder if he stayed at 4 or splurged on 8gb of ram…
    I am moving from a 4 year old G4 Dual gig….. so I am trying to find the value point on souping up this 3.2 power monster…
  • Walter Biscardi
    July 2, 2008 at 12:16 pm
    [Nate Stephens] “Wally B. always suggest 4 gigs.. But he did say he was getting a new 3.2 so I wonder if he stayed at 4 or splurged on 8gb of ram…”
    4GB would be a minimum for an older machine. With the Octo Core you want 8GB as the minimum. 1GB per core as noted by Gary Adcock on a thread recently.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • Mitch Ives
    July 2, 2008 at 3:09 pm
    On an 8-core, you’ll want a minimum of 8GB…
    Mitch Ives
    Insight Productions Corp.
    mitch@insightproductions.com
  • Nate Stephens
    July 3, 2008 at 9:12 am
    Thanks Walter,
    but did you say in that thread that you are running 10gb of ram… What combination did you use? 2-four gig modules and the stock 2-one gig modules? I thought I had read where you need to keep all the ram the same size in matched pairs…. filling a minimum of the first two slots on both ram cards…
  • Walter Biscardi
    July 3, 2008 at 11:38 am
    [Nate Stephens] “but did you say in that thread that you are running 10gb of ram… What combination did you use? 2-four gig modules and the stock 2-one gig modules? I thought I had read where you need to keep all the ram the same size in matched pairs…. filling a minimum of the first two slots on both ram cards…”
    Yep, that’s what you’re supposed to do. I ordered an 8GB Upgrade kit (2 4GB modules) and decided to just leave the original 2GB in there and see how it works out. So far it’s working so I left it all in there. If I have any RAM issues in the future, I’ll pull the original 2GB out.
    Read my Blog!
