Activity Forums Apple Final Cut Pro Legacy OPPS, Mixed 2 frame rates…. need to correct
  • OPPS, Mixed 2 frame rates…. need to correct
    Posted by David Stembridge on July 26, 2011 at 3:13 pm
    I had a 3 camera shoot, 2 Canon XHA1s cameras shooting HDV 1080i 24F and a third POV Drift camera shooting 1080i 25
    I thought I had converted the Drift footage properly; but it is still 25fps. When I mix the 2 cameras on a 23.98 based timeline, the drift camera stutters a little. If I set up a 25 based timeline, the Drift footage looks great; but the HDV footage stutters.
    I have tried multiple test exporting a small portion of the Drift footage; but can’t seem to get it matching.
    Any suggestions or advise please?
    Thank you!
    Jerry Hofmann replied 15 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 26, 2011 at 8:00 pm
    You can change frame Rates in Compressor.. Nattress’ plugin for this is better and faster than Compressor.. if it’s really mission critical, look for a place near you that has a Terranex Box. These do the best of the best with frame rate changes. Just edit as you have been in a 23.98 sequence, then in the end transfer only the footage you need if you go out to do the conforming.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
