Activity › Forums › Apple Final Cut Pro Legacy › Opinions on HDV workflow
  • Opinions on HDV workflow
    Posted by Eric on January 26, 2006 at 12:45 pm
    Hi Cow,
    we got a project here shot on HDV 16:9 pal. Using final cut studio. endprodukt 16:9 pal dvd (standart def.)We are not using a lot of effects work on the project(just hard cuts, crossdissolves and straight titles)
    I would like you to offer your opinions on the best workflow
    a) downconvert during capture (in camera) to DV, then edit, output to mpeg2 for DVD?
    b) capture HDV directly, edit, then output mpeg2 for DVD?
    is the image quality going to be significantly better on the DVD using workflow b? Do we have a more sluggish editing workflow using b?
    (using new g5 2.3 dual with 512mb ram, geforce 6600 gfx)
    >> Is it worth it using workflow b??
    Mike Smith replied 20 years, 8 months ago 4 Members · 3 Replies
  • Jerry Hofmann
    January 26, 2006 at 2:59 pm
    Seems it takes a very long time to compress HDV native to SD MPEG… That’s the killer, if the final program is short, it’s probably not a problem. For example, I’ve read of 2 hour shows taking days to encode to SD DVD’s…
    There’s a third option for you though. Might try the intermediate HDV codec if you can’t capture the material as true HD with capture card etc… This codec is an all i-frame codec, and should work great. Better than doing DV down conversion I’d think.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Jerry Alto
    January 26, 2006 at 5:06 pm
    Eric- An option we used was;
    Shot HDV>edit HDV native in FCP5> output HDV (now have HDV Master)> Component out of camera (need component analog video card) > FCP 8 bit uncompressed>FCP 8-bit uncompressed export to Compressor for mpeg2/DVD.
    A bit convoluted but we had excellent results and everything was real time (except for some minimal rendering/conforming in HDV timeline).
    Hope this helps.
    Jerry
    G5 Dual 3GB Ram
    FCP5 Studio
    External 1 TB SATA Raid 0
    Kona LH, Second system w AJA ioLA
    Sony Z-1
  • Mike Smith
    January 26, 2006 at 5:13 pm
    Why not work-flow test a 10 second clip – or better, 3 3 second clips with dissolves, picking a variety of your material – to see if you can see any difference in the end result.
    The downconvert-from-camera option will surely save you a lot of FCP rendering time ; if final delivery is (heavily compressed) mpeg2 for DVD, I’d be surprised if you see any benefit from the more difficult HDV workflows … .
    And report back your results ..?
