Activity › Forums › Apple Final Cut Pro Legacy › Operation not allowed+Error out of memory
  • Operation not allowed+Error out of memory
    Posted by Pmp-cep10 on September 2, 2007 at 6:12 am
    Hi everybody
    I’m working on two 45 min pieces witch is put together in several sequences. The first edit was made in dv and then reconnected from digi beta in 10bit uncompressed via black magic. the first pice is done snd gone worked fin same workflow. The secont peace contains more sequenzens. So i open my “big” sequenz and change all the sub sequenzes tu 10 bit uncompressed upper. As soon as i change the “big sequenz” to upper field i get the Error. If i switch the field dominance to none it workes aganin. I Checkt the HD space i have enoughf i trashed the fcp pref. What else could i try to do???
    Pmp-cep10 replied 19 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
