Activity Forums Adobe Premiere Pro Opening Project Very Slow
  • Opening Project Very Slow
    Posted by Laurent Dambier on April 25, 2009 at 11:18 pm
    I’ve got a little problem with my Adobe Premiere Pro CS4.
    I have a project wich has 200go of P2 rushes on another drive, and it take 25min to load.
    Is it normal? If not what can I do to fix that?
    Thanks a lot.
    Laurent Dambier replied 17 years, 4 months ago 3 Members · 3 Replies
  • Mike Velte
    April 26, 2009 at 10:12 am
    [Laurent Dambier] “If not what can I do to fix that?”
    4.1 update soon!
  • Eddie Lotter
    April 26, 2009 at 3:40 pm
    As Mike said. the 4.1 update, due end of may, has been announced as improving slow project load times.
    Unfortunately, until then, the only work around I can think of is to offline clips you are not currently using. That way, when PPro starts, it won’t open each clip to verify what it knows about the clips.
    Cheers
    Eddie
  • Laurent Dambier
    April 26, 2009 at 3:51 pm
    Ok, thanks a lot.
    Ok i’ll be waiting for the 4.1 upgrade 🙂
