Activity Forums Adobe Illustrator opening photoshop files.
  • opening photoshop files.
    Posted by Anne Pascal on September 5, 2005 at 8:47 pm
    Knowing how good the advice of the cows have been in the past, I trust that I am again not seeing the obviouly simple solution.
    My problem is that when I double click on a psd or jpg file, the file does not open in Photoshop CS. It does open the software but not the file. Same thing noticed when I try to open Photoshop CS from FCP 4.5 to edit some psd and tiff.
    Please help out
    Anne Pascal
    Richard Harrington replied 21 years ago 5 Members · 5 Replies
  • Del Holford
    September 6, 2005 at 5:34 pm
    some of your settings may have evaporated into cyberspace. your computer’s file manager usually has those associations (psd opens in PS CS, doc opens in Word, etc.) but sometimes the pc may hiccup and lose them. Try going into your file manager (Explorer in the IBM pc clone world) and re-associate those files. Then you should be able to use “open with”. I’m not that Mac fluent because I use PS CS and Illustrator CS on pc, but it has the same items, just calls them something different.
  • Anne Pascal
    September 6, 2005 at 7:59 pm
    Thanks for the email.
    However, I am a Mac G5 user and damn it, I still cannot find a solution.
    All my other files open nwhile double clicking: e.g ai files in ai, etc.
    Please help out.
    Anne
  • Seth Taylor
    September 6, 2005 at 8:05 pm
    I haven’t seen this before on my G5, but try resetting the preferences as you restart Photoshop.
  • Steve Denn
    September 7, 2005 at 12:05 pm
    Try reloading Photoshop CS. That should bring back your file association back
  • Richard Harrington
    September 10, 2005 at 6:17 pm
    Reload PS is best way… there ar a few files that get buried into the Library… if you upgraded your OS (like Panther to Tiger)…. it can delete or skip some of these…
    Back up your presets and plugins folders… then reload
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
