Activity › Forums › Apple Final Cut Pro Legacy › opening FCP 6 project in FCE 4
Posted by Charles Angelis on April 26, 2008 at 5:41 pmI have a client who is trying to open a project I worked on and saved in FCP 6 in FCE 4. They tried opening the project in FCE and it would not open. I didn’t they would be able to, so I exported an XML out of FCP 6 but they were still not able to open it. Why wouldn’t FCE open and re-create the project from the XML?
Richard Harrington replied 18 years, 5 months ago 6 Members · 11 Replies -
Zane Barker
April 26, 2008 at 6:46 pmWhat format of video are you using in FCP. The reason I ask is because FCE is vary limited on the formats it will use.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
Charles Angelis
April 26, 2008 at 6:49 pmIt is DVCPRO25. The project files came to me originally from FCE 4 and I opened and (re-saved as a different project) in FCP 6.0.3. My client tells me they can’t open either the project I worked on and saved in FCP 6.0.3 but also the XML export I created as a backup.
Zane Barker
April 26, 2008 at 6:54 pm[Charles Angelis] “DVCPRO25”
I believe that FCE is limited to DV & HDV.
Charles Angelis
April 26, 2008 at 6:56 pmThis doesn’t make sense to me. The media I am using came from FCE. I did not change the sequence settings.
Zane Barker
April 26, 2008 at 6:58 pmWell then its probably not DVCPRO25.
Zane Barker
Charles Angelis
April 26, 2008 at 7:00 pmThe Sequence is DV/DVCRPO NTSC. I don’t remember what the item properties for the clips was. Any idea why I can’t round-trip a project from FCP 6 to FCE 4, even with an XML? Is it that FCE does not have XML import abilities?
Walter Biscardi
April 26, 2008 at 7:11 pm[Charles Angelis] “Is it that FCE does not have XML import abilities?”
No clue if they do, but be sure to save it off as an early XML format. FCP 6 offers 4 levels of XML file save. I find that when I send XML’s to folks with FCP 5 or earlier, I need to save it off as an XML Version 1 or 2.
Might be the same with FCE.
As a rule, FCE does not work well at all with FCP projects.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Arnie Schlissel
April 26, 2008 at 10:06 pmI don’t think that FCP projects are “downward” compatible to FCE. And I don’t know that FCE has any XML import or export, either.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
Tom Wolsky
April 26, 2008 at 10:24 pmFCE4 does have XML import. You might try versions 1 and 2 of XML. There also might be something that was done in FCP project that FCE cannot parse in the XML file.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop”
