Activity Forums Maxon Cinema 4D opening curtain in cinema 4d
  • opening curtain in cinema 4d
    Posted by Victor Camacho guerrero on August 22, 2011 at 11:00 am
    Hi all,
    I am setting up the usual opening with a curtain in Cinema 4d. I got almost everything setup. I created a plane, which I converted in a cloth. I used a cloth tag, a belt tag and finally a cloth Nurbs. In order to animate it, I wanted to move the whole null, but it does not work . I did once, however no idea how I did it and i cannot do it again.
    The file is attached here to download. If someone knows a solution for this, would be great.
    https://www.switchfire.net/curtain.c4d
    Thanks a lot
    Manuel Aguilera replied 12 years, 1 month ago 4 Members · 4 Replies
  • Adam Trachtenberg
    August 22, 2011 at 2:08 pm
    The correct way to do it is to animate the belt object.
  • Brian Jones
    August 22, 2011 at 2:16 pm
    – you did not animate Null1 – it has keyframes but they are both at the same coordinates
    – the curtain under Null1 has the belt points also Fixed in place (that has to be cleared)
    – Adam is right, the best way is to animate the belt object
  • Victor Camacho guerrero
    August 22, 2011 at 2:36 pm
    Hi guys, thanks a lot for your quick answer. I have fixed the problem as you said. The main problem was in the fixed points. Now all it is fine. and I really appreciate your help.
    Thanks a lot
  • Manuel Aguilera
    July 17, 2014 at 12:29 am
    Hey victor! can you help me plz, I have the same problem! hablas espanol?
