Activity Forums Adobe After Effects Opening an discussion about NTSC: 648×486 vs 720×540 I just read the whole string
  • Opening an discussion about NTSC: 648×486 vs 720×540 I just read the whole string
    Posted by Joeythedog on August 2, 2005 at 10:01 pm
    Ok so someone creates a huge project using the correct formats for standard television. Then they also realize that they will also need to be create the same piece for high definition. Does one have to do the entire project over again from square one?. Keyframes, animtions, titles,effects, masks, the whole works, to have a finished piece to play on a flat panel high definition monitor?
    Scary thought
    Steve Roberts replied 21 years, 1 month ago 2 Members · 1 Reply
  • Steve Roberts
    August 2, 2005 at 10:03 pm
    Work in the big HD comp, then scale down the render by dropping the comp into a smaller comp, or by scaling/stretching in the output module.
    By the way, if you render fields, never scale in the output module.
    Steve
